15" 195 or 205?
Old Dec 18, 2008 | 09:35 AM
Spooling's Avatar
15" 195 or 205?
Which width is ideal for 15x7 Enkei RPF1s +41? Coilover is Skunk2 Pro-C's.
195 is lighter but 205 has that unique stance?
Old Dec 18, 2008 | 09:47 AM
dewthedew's Avatar
rpf1s with 205s https://www.fitfreak.net/forums/fit-...ttle-drop.html
i have some rubbing issues in the front when i hit bumps in fast turns.. im on skunk2 springs. 195s wont have any rubbing issues but 205s will give you better cornering and an awesome stance.
Old Dec 18, 2008 | 12:19 PM
NBPturtle's Avatar
Agreed. If you go 195, you might get a small stretch on the tires. 205 would look better with the RPF1 IMO
Old Dec 18, 2008 | 12:39 PM
fibinochi's Avatar
having 205's will not nesseccarily give you better cornering, as some people have stated that you lose turn in. also, your rubbing, so how can you be cornering better? cant say anything bad about the stance, it looks great!
Old Dec 18, 2008 | 01:41 PM
mahout's Avatar
Our turn-in and exit improve with 205/50x15 over 195/50x15's. So does lap times.
Old Dec 18, 2008 | 01:49 PM
dewthedew's Avatar
rubbing issues has nothing to do with how my car corners.
Old Jan 19, 2009 | 02:25 AM
chinkyy's Avatar
wouldnt a car dropped at the same height that doesnt rub turn faster the exact same car that rubs? because something is interfering with the tires rotation
Old Jan 19, 2009 | 02:27 AM
kylerwho's Avatar
spoon fed
rubbing = resistance = slower tire rotation. it seems logical.
Old Jan 19, 2009 | 04:24 AM
chinkyy's Avatar
lol ya but i dont know much about tires and stuff like that so i was just wondering
Old Jan 19, 2009 | 07:32 AM
mahout's Avatar
Rubbing does interfere with rotation of the tires; so its slower. The more rubbing the slower you go.
There's a little more to it than that. Control can also depend on which tire is rubbing. If the outside front tire rubs steering will be reduced, making for more understeer. Also reduce turn-in.
If its the outside rear tire oversteer can be increased. In both cases the car wuill be slower; the harder it is to turn the wheel and tire the more power is lost and therein acceleration.
Old Jan 19, 2009 | 09:58 AM
eldaino's Avatar
get a better offset
dont lower
or if you do, lower for performance, not looks.
if you want to be slammed, roll your fenders.
ta-da!
Old Jan 19, 2009 | 11:53 AM
dewthedew's Avatar
I really want to figure out what its rubbing on.. theres no signs of wear (yet).
Old Jan 19, 2009 | 01:33 PM
im the fit's Avatar
for the rear it could be the shocks rubbing on tire or on the front it could be the fender liner or the A arm
Old Jan 21, 2009 | 12:43 PM
i would go with 195/50/15's.
Old Jan 21, 2009 | 12:52 PM
JDMxGE8's Avatar
205/50/15 would be the optimum choice.
Old Jan 21, 2009 | 03:25 PM
Fit_Dr's Avatar
Can you raise the car a tad to avoid rubbing or is it simply rubbing on the coilover body?
I'd go with the 205/50/15 and play with the tire pressure. They won't necessarily be heavier depending on the tire you get. After researching this quite a bit on my own I'd suggest Michelin Pilot Exalto PE2's.
If changing wheels is an option you might even consider a 15x6.5 and/or a +44 offset.
Old Jan 27, 2009 | 11:36 AM
AP_ONE's Avatar
100% agree, many more benifits to this then a 205 (wow)
Old Jan 27, 2009 | 12:27 PM
rvall004's Avatar
195.....all the wayyyy
Old Jan 29, 2009 | 12:50 AM
fitinfit's Avatar
195 for me! for such a little car, with so little power, 195 is the best choice.
SBT
Jan 18, 2012 03:43 AM
phenoyz
Oct 26, 2010 02:39 PM
Nighthawk_GD3
Aug 15, 2009 01:33 AM
dewthedew
Dec 13, 2008 08:25 AM
YeeFit
Oct 10, 2008 07:48 PM
