FIT-Vendor Sponsored Group Buys and Sales Organize group buys to get discounts. Only Forum Sponsors may post group buys in this sub-forum. Forum Sponsors will have "FIT Vendors" in their user title and have gone through a screening process by FIT Freak staff.
Universal 6LED Boards - For your Interior & Exterior!
Old Dec 11, 2008 | 07:40 PM
LuxuryMods's Avatar
everyone!
We have a few of these that will definitely spruce the inside of your Fit @ night. Stock bulbs simply do not cut it! These will fit nicely for your dome or trunk light!
They are 6LED (only 6, but BRIGHTER than other 9 bulb models we've seen)
Price = $16.95 shipped each
Combo (2 boards) = $29.98 shipped!
You can order direct through the site link below!
https://www.luxurymods.com/index.asp...ROD&ProdID=639
Here are a few pictures installed into the dome light of our Fit...
Installation instructions are easy! Plug & Play
1) Find the correct size bulb adaptor and connect the led board.
2) Remove the 3M tape and mount to flat surface, tuck the wires neatly away. LEDs are polarity sensitive, so if they do not light up, simply flip the bulb in the socket the other way around.
3) Put the cover back on and test it out! Look how bright they are in the daytime!
This YouTube video also shows how they will turn on when you unlock your car doors and dim, then turn off when you lock the car. (If your dome switch is set to "door")
Old Jan 19, 2009 | 05:46 PM
LuxuryMods's Avatar
bump!! Just received another shipment of these lights...they are super bright & will not disappoint!
Old Jan 19, 2009 | 06:20 PM
jrlnc's Avatar
Exclamation Not to be critical . . .
but it looks a little odd that they're off center.
Is it possible to center them?
I'd be interested if not for that.
Old Jan 19, 2009 | 06:23 PM
LuxuryMods's Avatar
Most definitely! The backing is simply 3M tape, so you can tape it directly in the center if you'd like.
Or, if you don't like using the adhesive, you can work the wiring properly to make the board sit in the middle.
I'll try to snap a nice night-time shot of these on, it truly lights up the entire interior.
Old Jan 19, 2009 | 09:15 PM
manxman's Avatar
Order placed. Thanks!
Old Jan 19, 2009 | 09:25 PM
secondspassed's Avatar
will these work to replace the stock bulbs in the GD3 JDM Map lights? I'd like to upgrade the hatch and dome lights but it would be silly if my maps couldn't be changed to match.
Old Jan 20, 2009 | 02:10 AM
LuxuryMods's Avatar
Got it! Will be sent out tomorrow!
These come with 5 of the most common socket types to fit almost any vehicle, anywhere!
Please see the image below to see if the adaptor will work for you. I am assuming the jdm map lights would either be the spade or wedge?
Sorry for the blurry picture, but here it is for the dome, it lights up almost the entire interior!
Old Jan 20, 2009 | 04:20 AM
xxgotfit?xx's Avatar
i bought a similar set of these from atticus fit, but it seems that yours are lighter and clearer than his, can you confirm this? i'd like a set, oh btw i live near GG, maybe we can meet up?
Old Jan 20, 2009 | 10:40 AM
LuxuryMods's Avatar
Yes, we can meet up one of these evenings so you can see them in person. Please let me know when you would like to meet.
Old Jan 24, 2009 | 06:23 PM
manxman's Avatar
I ordered and received two of the 6 LED universal kits, and installed one in the cargo light, and the other in the dome light of my '09 Sport. By comparison, the stock bulbs shouldn't be called "lights". They are "darks". The new LEDs are at least twice as bright as stock. The cargo light even illuminates the inside of the little storage compartment on the opposite wall. A really effective improvement for a small price. Thank you Tony.
P.s. jrlnc-- the "dummy light bulbs" that connect the wiring of the LEDs to the contacts in the car are plastic and do not light up or generate heat. I just stuck the tape on the back of the LED boards right to the plastic tubes, so that the LEDs were centered in the cargo and dome light fixtures.
Old Jan 25, 2009 | 03:02 PM
artieman's Avatar
they also make a kit with the same high output led for a lot less on ebay without the funky pcb board
http://imgs.inkfrog.com/pix/1Som_Bidsome/42six.jpg
Old Jan 25, 2009 | 03:32 PM
LuxuryMods's Avatar
Sure you can go that route, but most of these I've seen will not fit in the dome or cargo area unless you have the remote mount board. Having it this will allows for various different installation spots and the opportunity to fit a larger board.
Thanks for your input.
Old Jan 26, 2009 | 02:28 AM
Chanh55's Avatar
Thanks for the awesome deal. These LEDs are so bright! I was able to mount it right in the center of the housing so it lights up the cabin evenly. Here are some pics:
Old Jan 29, 2009 | 09:35 PM
Guinness's Avatar
LOL, i wouldnt want anyone turn that on when I am driving... its like a FLASHBANG
Old Jan 30, 2009 | 03:51 AM
holy crap! they are lighter! i think i want a set now!
Old Feb 8, 2009 | 06:33 AM
cKranez's Avatar
hey umm where are u guys located i live in rowland heights... wondering if you're ever in the area i can pick it up off of ya
Old Feb 9, 2009 | 01:41 AM
LuxuryMods's Avatar
I'll be in the Diamond Bar area on Wednesday...let me know!
MonstaMatt
Feb 14, 2026 10:10 PM
ADVphotography
Jul 16, 2014 04:13 PM
over40pirate
Apr 25, 2013 12:25 PM
madparrot
May 10, 2012 02:04 PM
IN2TURBOS
Mar 2, 2010 06:22 PM
