Wr manifold testers..
Old Feb 3, 2009 | 02:08 PM
WRLEO's Avatar
Looking for 5 Test cars to test out the Weapon*R manifold..
Will give a discount to the takers... ( PM for Details )
New Design.. No CEL...
Here is the pictures of the Completed Manifold:
Old Feb 3, 2009 | 03:02 PM
rvall004's Avatar
u got pmed!!!
Old Feb 3, 2009 | 03:47 PM
ghg78's Avatar
bump for pm.
Old Feb 3, 2009 | 03:53 PM
FELIXY69's Avatar
u got pm ~!!!!!!!
Old Feb 3, 2009 | 04:24 PM
YeeFit's Avatar
Oooooooh so pretty and shiny! I'd be willing to put my car out there to test this out and try to make more power
PM'd
Old Feb 3, 2009 | 04:40 PM
Sypd3r's Avatar
I just PM'd you.
Old Feb 3, 2009 | 05:40 PM
Sugarphreak's Avatar
Push My Button
Is this the USDM or the JDM shown here If this is the USDM model shown I don't understand what is happening on the back of the plate. I wouldn't mind a bit of information on how this works, my Rev2 WR manifold has the EGR port located in the center. This looks like some kind of bypass or re-routing.
Old Feb 3, 2009 | 10:48 PM
gimme's Avatar
Master FitFreaker
must the vehicle be local? MT or AT?
Old Feb 3, 2009 | 10:49 PM
dewthedew's Avatar
Ill test it!!!
Old Feb 4, 2009 | 01:18 AM
Slimjimx701x's Avatar
PM sent (10 char min)
Old Feb 4, 2009 | 09:42 AM
alf74's Avatar
Can I buy the old one not working?
Old Feb 4, 2009 | 03:19 PM
kylerwho's Avatar
spoon fed
i now have one on the way.
looks like i will be running this on N/A setup for about a week then comes the boost!!!
Old Feb 4, 2009 | 03:41 PM
gimme's Avatar
Master FitFreaker
AWWW, i want to test one
Damn all you ninja pm'ers!
Old Feb 4, 2009 | 04:11 PM
Push My Button
Please post lots of pics of the front and back of that lower flange, maybe some measurements as well would really be a lot of help.
Old Feb 4, 2009 | 04:56 PM
alf74's Avatar
You're right. This manifold won't fit usdm model because in this way egr is completely tapped!!!
This is the Jdm model!!!!!
Old Feb 4, 2009 | 04:59 PM
DrKelso's Avatar
You see that large (presumably 1/2") nipple between the 2 middle runners? You have to re-route your EGR tubing there.
This is exactly how it is on mine and I still have the CEL
Old Feb 4, 2009 | 05:19 PM
alf74's Avatar
Re-routing your EGR tubing there you'll always have CEL because ecu monitors egr through map sensor.
EGR valve reduces intake vacuum and replaces some intake airflow with EGR flow.
In this way map sensor doesn't feel anything...
Why the back of the plate is like jdm model then?
Old Feb 4, 2009 | 08:27 PM
kylerwho's Avatar
spoon fed
here is a picture of the stock USDM intake manifold aluminum runner that bolts to the head.
looks differant to me.
Old Feb 4, 2009 | 09:55 PM
WRLEO's Avatar
Lemme try and explain what we did..
The reason why the ECU was seeing LOW EGR flow was because it needed to flow back into the cylinder head..
Look at the This picture of the USDM HONDA FIT.
EGR gases come from the EGR Actuator ALONG the GROOVE on the Cylinder head.
The EGR Gases flow through the BACK side of the manifold.
From the backside to the front side of the manifold, and gets re-distributed to the 4 intake ports and back into the engine..
The reason for the CEL with the old design is The EGR gases were not being distributed and the flow wasnt flowing at the rate it was supposed to be flowing at. Now if you look at the picture of the Cylinder head there are 4 wedges that allow EGR flow to flow back into the intake ports..
What we have done is Bypass all the flowing through the manifold etc.. etc.. ( PICTURED in pictures#1-3 ) is directly let the EGR gases flow from the EGR Actuator and evenly distribute the EGR Gases back to the intake ports..
This is basically doing the same thing that the OEM manifold was doing, which is true by looking at an OEM USDM Intake Manifold Gasket..
Flow comes from the middle and then needs to go to the 4 intake ports..
I hope i have explained it so everyone can understand what we did..
File Type: jpg
Old Feb 4, 2009 | 10:00 PM
Push My Button
That is fantastic, much appreciated for the information Leo!
Wow, there is a lot going on here that I was not aware of.
