Sponsored by:
Sponsored by: CARiD
Check Engine light came on today!!
Old Feb 10, 2009 | 12:43 PM
Skytraveler's Avatar
My check engine light just came on this morning. I have just above 12K on the vehicle. I had the yellow wrench come on about a week ago and B 1 indicating (oil change, rotate tires, and inspection of several items). I was going to call the dealer this morning to make an appointment when the check engine light came on.
So I called and made the appointment just now. First thing the guy asks me is if I just put in gas in the car. I told him I put gas in the car 4 days ago. He tells me to check the gas cap (now I always click the gas cap at least 3 clicks if not more). Nonetheless he says anything that they find will be under warrenty.
Can't wait to get this car all taken care of. I'll report what they find on Saturday.
peace,
Old Feb 14, 2009 | 11:46 AM
ok came back from Coggin Honda Ft Pierce and they retrieved the code P2646 (VTEC Oil Pressure Switch Circuit Low Voltage). The check engine light was on for only a and a half then it went off.
They told me that it the check engine light comes back on for the same code, that I would need to leave it with them for them to diagnose.
There's another thread about the rocker arm oil pressure switch on the board started by mattpuchlerz, that has the exact opposite of my code.
His is P2647 which says is VTEC Oil Pressure Switch Circuit High Voltage even though his is documented as a rocker arm oil pressure switch (probably the same thing).
Anyhow they said it could have been the oil level. I don't think the level was low though my oil life was at 5%.
Today I basically had the 10,000 mile maintenance done, oil change, rotated tires etc etc. Hopefully I do not see the engine light come back on any time soon.
Peace,
Old Jun 23, 2010 | 05:47 AM
JamesBizzle's Avatar
I had this problem today. I checked my oil level and saw that it was about a quart low. So I added a quart, reset the code and it never came back on.
I've also read that cleaning out the screen/filter for you VTEC oil pressure Sensor or changing out a bad sensor will remedy this as well.
Just in case anyone out there runs into this problem.
Old Jun 23, 2010 | 06:21 AM
Contrabida Face's Avatar
subscribed. thanks for the info
Old Jun 23, 2010 | 09:03 AM
Krimson_Cardnal's Avatar
Oofie also went through this yesterday with a P2647, https://www.fitfreak.net/forums/fit-...tml#post874181
P2646 and P2647 are both related to the Rocker Arm Oil Pressure Switch Circuit
P2648 and P2649 are both related to the Rocker Arm Oil Control Solenoid Circuit.
It seems these codes show up as intermittent problem at times and can be related to oil pressure/levels.
Lesson here seems to reinforce to need to run at correct oil levels - be sure to post back any future issues.
K_C_
Old Jun 24, 2010 | 11:14 PM
TheRealDooder's Avatar
you cant rely on that oil % gauge. always check for yourself, you were most likely a little low and tried to hit vtec and the lack off oil threw the code.
Old Jun 25, 2010 | 09:03 AM
You might be missing something here - the oil gauge you refer to is a "% oil oil life" indicator as tells you when to change the oil.
You are correct - always check the level yourself. I check at least once a month. And yes, it seems running low oil and hitting peak RPM might trip these codes.
K_C_
The Barroom Hero
Mar 13, 2014 07:23 PM
A-Diggy
Jul 23, 2013 01:38 AM
TrippKnightly
Jan 9, 2013 12:48 AM
Tomh
Jul 2, 2006 09:35 PM
sam
May 4, 2005 11:16 AM
