Defrost and mileage?
Old Feb 12, 2009 | 10:30 AM
FittJedi's Avatar
So everyone knows that the defrost setting cycles the A/C (there's even a thread for disabling it). I was just wondering if anyone knows the particulars of how this works. . . for instance, is the compressor on the entire time you're using defrost, or does it just cycle for a little bit? Can we expect any effect on mileage when using defrost constantly? Thanks.
Old Feb 12, 2009 | 11:17 AM
polaski's Avatar
On my GD3 I took an extended trip that past June and it was humid enough to need the defroster, plus that crud Honda left on the inside of the windshield made it worse so I left it on the whole time. That was about 225 miles across da UP after dark so I could see the lights dim every time it engaged.
The compressor wasn't running the whole time, but it was dimming the lights every couple minutes. On the bright side I got 43 mpg that tank.
Old Feb 12, 2009 | 02:56 PM
pb and h's Avatar
There is a mod I posted for this problem. The defrost runs the A/C thus killing your mpg. For some reason honda thought it wasn't worth adding an additional button to turn off the A/C for defrost.
Old Feb 12, 2009 | 02:59 PM
pb and h's Avatar
Found it:
https://www.fitfreak.net/forums/eco-...5-defrost.html
Enjoy! - You know I never did this mod, too lazy I guess.
Santiad
Oct 3, 2012 11:18 PM
boomboxbeat
Mar 28, 2011 12:40 AM
warner
Sep 13, 2009 10:54 AM
dgs
Aug 2, 2009 09:25 PM
Firebat666
Jun 11, 2008 11:55 PM
