Wr manifold testers..
Old Feb 17, 2009 | 09:30 PM
  #81
kylerwho's Avatar
spoon fed
put the wideband right in between the senor in the header and the sensor that is supposed to be past the cat. roughly 12 to 14 inches down stream of the head.
Old Feb 17, 2009 | 09:47 PM
  #82
dewthedew's Avatar
so i see that they are welding the race header instead of using the slip design
Old Feb 17, 2009 | 10:34 PM
  #83
WRLEO's Avatar
Originally Posted by Sugarphreak
I need to pick up a wideband and have another bung installed this weekend, would you recommend it on the header or the B-pipe?
I would recommend you put it in the header..
depends if your going to use it all the time or just for tuning..
If your going to keep it in all the time.. i would just get a Innovate LM-2..
That way you dont need to have that think in there all the time. just take samples from your tailpipe for tuning.. and it also does OBD2 scanning ..
Also it can do data log and read what all your sensors are doing.. which is a good idea.. Better than buying just a wideband.. atleask this is a wideband and tuning tool all in one..
If your just going to leave it in the car.. put it near the last O2 on the header..
We have o2 bungs also... you shoulda told me i would've got you one...
Old Feb 17, 2009 | 10:58 PM
  #84
Sugarphreak's Avatar
Push My Button
I need it just for tuning
It had totally slipped my mind when I ordered the header
Old Feb 17, 2009 | 11:15 PM
  #85
WRLEO's Avatar
I suggest you get the innovate LM2...
Old Feb 18, 2009 | 11:52 AM
  #86
Push My Button
Looks like I will be picking up something pretty similar, a portable LM1 unit
Old Feb 18, 2009 | 06:10 PM
  #87
Push My Button
Looks like this is the one I will be getting in the end, no stock left on the LM1's anywhere
What makes the LM2 worth so much more than the LM1
Old Feb 24, 2009 | 01:20 PM
  #88
Push My Button
Getting closer, going to pick up the header this afternoon with the new bung installed. I ended up going with the full LM2 kit.
Sunday is the big install day for everything
Old Feb 24, 2009 | 02:39 PM
  #89
Tofuman's Avatar
cool. can't wait to hear the outcome.
Old Feb 24, 2009 | 03:10 PM
  #90
kylerwho's Avatar
spoon fed
im really curious for sugarphreak to dyno test again to see his results.
Old Feb 24, 2009 | 03:25 PM
  #91
Push My Button
Yeah I should really be able to dial things in for an accurate results this time around.
This is the LM2 kit I picked up, is sweet
Old Mar 1, 2009 | 07:23 PM
  #92
Push My Button
Race Header and Revised intake manifold are IN!!
And no CEL
Race header provides a noticeable low end response, I am interested to see how the numbers play out on the dyno.
I was however running rich, my AFR was 14.6 at idle, but it dropped down to as low as 10.0 on WOT. It needs to be tweaked quite a bit yet.
Old Mar 3, 2009 | 06:03 PM
  #93
WRLEO's Avatar
AT WOT.. THATS SUPER FAT... I've never seen a NA car that FAT... CRAZY.. Get that thing tuned in bro.. for optimal tune i would run 13.8-12.5 at WOT...
Old Mar 3, 2009 | 06:56 PM
  #94
Masterdebater's Avatar
so what all do u have on ur fit now sugar? i want mine to sound that way lol
Old Mar 3, 2009 | 08:38 PM
  #95
Push My Button
Yeah when I first installed the manifold down in Van because of the EGR issue it leaned the AFR out a lot... what you are seeing now is the E-manage tune I had at the time to counter it going overkill until I can start tweaking it to bring it back up a bit.
This is one of the reasons why my car only made a bit more power than stock on my last dyno.... that and the ECU was throwing in even MORE fuel than now because of a CEL.
I am confident we are going to see some BIG numbers out of this car in a bit!
Old Mar 3, 2009 | 08:41 PM
  #96
Push My Button
Lets see if I can remember just power mods;
-T1R Response Header > Swapped out for WR Race header
-Cat Removed
-T1R B-Pipe
-T1R 50S Exhaust
-UR Pulley Kit (I think I am the only Fit to have both pulleys installed)
-Greddy E-Manage Ultimate
-Fujita CAI > Swapped out for WR intake w/ cold air extension
Will be tuned with the above mentioned LM-2
Old Mar 3, 2009 | 09:53 PM
  #97
kylerwho's Avatar
spoon fed
just remove the greddy emanage and run with the stock ecu to correct everything until you get your tune on.
Old Mar 3, 2009 | 11:40 PM
  #98
Push My Button
Better rich than lean for the moment, I will have a chance to do some corrections soon.
Old Mar 4, 2009 | 12:44 AM
  #99
kylerwho's Avatar
spoon fed
if your not throwing a code then you shouldnt be running lean if you go back to the oem ecu. it will figure out itself.
Old Mar 4, 2009 | 07:22 AM
  #100
azkikersfit's Avatar
nice, will this work on JDM?
