Tire, Wheel, Brake & Suspension Welcome to the FitFreak.net Tire, Wheel, Brake & Suspension Forum
offset question
Old Mar 4, 2009 | 04:08 PM
FITtin''s Avatar
Ok, thanks for the info, Jim. Will put my order to Tirerack shortly.
Old Mar 4, 2009 | 05:54 PM
mahout's Avatar
Originally Posted by jim@tirerack
The tire should be either a 195/55R15 or you can go with a 205/50R15. If I can help let me know.
I vote for Jim's 205/50x15. Nice thing is there are several very good choices. Use TireRack's testing venues to see which onesuits you best. Jim can run you thru them. good luck.
Old Mar 30, 2009 | 09:49 AM
FITtin''s Avatar
Unfortunately, I went with the 195/55/15 and they are rubbing alot (in the rear).
Old Mar 30, 2009 | 10:13 AM
jim@tirerack's Avatar
Former Vendor
If the 195/55R15 is rubbing I would suggest a little more negative camber and or rolling the fender lip. The 195/55R15 is the narrowest size I would recommend for the car.
intafocus
Apr 21, 2011 03:16 PM
Blueputtputt
Apr 29, 2010 12:55 AM
sbualuba
Jan 31, 2009 02:04 PM
KnifeEdge_2K1
Dec 26, 2007 11:09 PM
JDM_FIT
Oct 13, 2005 12:31 AM
