Wr manifold testers..
Old Mar 8, 2009 | 01:40 PM
  #101
WRLEO's Avatar
Yes it will work on JDM cars..
Old Mar 8, 2009 | 01:49 PM
  #102
porkchop's Avatar
will it fit on the ge8
Old Mar 8, 2009 | 01:53 PM
  #103
kylerwho's Avatar
spoon fed
weapon r is working on one for the ge8 last time i heard.
Old Mar 8, 2009 | 01:54 PM
  #104
WRLEO's Avatar
Still working on that...
Old Mar 17, 2009 | 11:01 PM
  #105
artieman's Avatar
Would you still be willing to sell me one of the old manifolds? I have an electrical work around so I can block it without cel.
Old Mar 18, 2009 | 12:28 AM
  #106
Sugarphreak's Avatar
Push My Button
Without the EGR circulating you will end up with a very lean mix, I suspect a lot of unburned fuel gets reintroduced in this process.
Old Mar 18, 2009 | 12:34 AM
  #107
artieman's Avatar
lean is not an issue since i have the ability to correct the a/f ratio...
Old Mar 18, 2009 | 01:09 AM
  #108
Push My Button
I did as well with mine, but despite that it still felt very bogged down. I think the EGR system plays a more critical part than most people are aware of.
Anyway, just my thoughts on it. I have been running around for almost a year with 2 different versions of this manifold that block the EGR. Since I did the swap out of the header (T1R for WR) & new manifold I have noticed a pretty significant difference in the low end power and this despite the fact my car tune is way too rich right now.
Today I surprised myself, I downshifted to pass somebody and I got way more power than I was expecting. It is strange, from a steady acceleration from 0-60 it seems like the car is laboring pretty hard (still better than stock), but it responds almost unexpectedly to jolts of throttle and then sustained acceleration.
I still need to play around with a few more things, I have a WR SRI intake waiting to be installed (to replace the Fujita CAI) and some new wheels to throw on in about 2 weeks. I also need to spend some quality time with my E-manage, my LM-2 and a laptop. I still have plans to hit the dyno again and see if all these adjustments make a big difference.
Old Mar 18, 2009 | 01:29 AM
  #109
artieman's Avatar
exhaust gas recirculation is a bad thing for power output...its for emission control and is part of why the fit has the LEV rating...
im using a custom fuel management system and also using the innovate lm wideband
getting the car to run properly without pumping exhaust back into the cylinder will always make more power.
Old Mar 18, 2009 | 03:40 AM
  #110
gd3kamiwanaB's Avatar
Luvs Dah b00st!
yes but pumping exhaust back into the cylinder is also done to cool the cylinder controlling NOX levels. with out an egr system on a modern fuel injected motor the cylinders would over heat causing oil to burn off the walls and lead to scratching of cylinder walls.
Old Mar 18, 2009 | 11:18 AM
  #111
artieman's Avatar
The cylinders would overheat is way off base...fuel cools the cylinders which is why high horsepower boosted cars run rich...pumping hot exhaust back into the cylinder would not cool it. But by pumping exhaust back into the cylinder your reducing the room for fuel and oxygen which reduces power and heat (you can cause the exact same thing by letting up on gas pedal ). Honda has a lot of different fuel injected engine models without egr on them.
Old Mar 18, 2009 | 12:31 PM
  #112
Push My Button
Logically you will get no arguement from me, on paper this looks good
I just wasn't getting the results I wanted with it blocked, I was using the E-manage Ultimate tuned by AJRacing. Now that I am running with it flowing I can tell the differance, like I was saying before I suspect there is more going on here than just an efficency process.
Anyway, not looking to debate it. I am just sharing my experience
Old Mar 19, 2009 | 02:30 AM
  #113
Shaggs2Dope's Avatar
Frequent FitFreak Poster
Damn, thats a nice bunch of goodies, It's gonna be sick when everything is set.
Old Apr 4, 2009 | 10:24 AM
  #114
azkikersfit's Avatar
so wtf up wid dis? it just died out? no one doin any dyno runs or reviews with this manifold ?
Old Apr 4, 2009 | 02:16 PM
  #115
WRLEO's Avatar
Waiting on these guys.. I gave deals to about 12 people..
This is NOT COOOL..
Old Apr 22, 2009 | 11:22 AM
  #116
Push My Button
Car is tuned, wheels are finally here (tires arived Monday); Dyno is tenatively scheduled for May 17th
Old Apr 22, 2009 | 11:47 AM
  #117
artieman's Avatar
no before and after dyno runs makes it pointless...and how did you tune it without a dyno? You can get the a/f ratio close street tuning but you cant do timing on the street.
Old Apr 22, 2009 | 11:54 AM
  #118
Push My Button
Street tuned doing 2nd gear pulls and then adjustments from the logworks graph to the E-manage map to hit my target A/Fr's. Naturally the dyno will also be used to make final adjustments based on the power output.
Old May 2, 2009 | 12:03 AM
  #119
explosivpotato's Avatar
Not having EGR is going to throw off your timing. EGR requires a lot of extra timing. Just turning it off will cause you to detonate. The reason it felt bogged is probably because you were bouncing off the knock retard.
EGR doesn't do anything at WOT anyway, so there's really no benefit from turning it off. It improves mileage too, as well as emissions.
Old May 2, 2009 | 12:15 AM
  #120
Push My Button
The new manifold allows for free flowing EGR
