Skunk 2 Springs DIY gone wrong
Old Mar 12, 2009 | 07:31 PM
score04w's Avatar
So i just got a set of skunk 2 lowering springs for my 07 fit. The first problem was that the springs in the back were put in so that the skunk 2 logo was upside down. When i went to put the front ones on, the logo was the right way, so you could read it. Did put them on wrong? It was the only way they would fit. Here's the second problem, or the bigger one. I got the springs on, and found out that the strut is walking around, or not securely fit where the rubber fitting meets the body under the hood. So every time the wheel turns, the struts shift around, and a lot. Has this happened to anybody else, or again, did i do something wrong?
Old Mar 12, 2009 | 08:25 PM
suketoborudo00's Avatar
humm i do not have springs and haven't installed them before but I don't think that sounds safe.. be careful in the mean time when someone answers your problem
Old Mar 12, 2009 | 08:32 PM
enjoito's Avatar
the name and number is suppose to be up right.
Old Mar 12, 2009 | 08:58 PM
Mr_ET's Avatar
I have installed multiple suspension kits on fits and what you describe would be an error in installation.
Is there a buddy with some experience that could come over and help you?
Old Mar 12, 2009 | 10:06 PM
enjoito's Avatar
i have a problem that the rear corner is higher then the other side and i installed it the same way.
Old Mar 13, 2009 | 12:58 AM
score04w's Avatar
no help really, the back springs i guess are in wrong because the logo is upside down, but they wouldnt go in any other way. im really worried about the front because the struts are walking all over the place. Im about to go back to stock, and wait to buy some tokico illuminas or full coils.
Old Mar 13, 2009 | 01:03 AM
Fa1's Avatar
Fa1
The rear sounds right iirc from other users' installs. The front is definitely wrong. Try tightening the top bolt more or check for any missing parts. The top is only suppose to rotate.
Old Mar 13, 2009 | 01:07 AM
score04w's Avatar
the top is only supposed to rotate?
today when i was working on it i had the hood open, every time i turned the wheel all the way from one side to another, the black caps that are visible from the engine bay would shift and move around.
Old Mar 13, 2009 | 01:42 AM
Fa1's Avatar
Fa1
That's the shock that goes up and down. The complete assembly does not move in the hole where the strut goes through.
To be more exact the rubber/metal pieces hold the strut in place so that the strut only rotates and up and down within the rubber/metal pieces.
The rubber/metal pieces on the top visible from the engine bay and the same piece within the fender well do not move.
Old Mar 13, 2009 | 07:48 PM
90crxfreak's Avatar
i offer know help but lot of moral support.... also i'm coming up to fairfield to see my girl this weekend, to bad your about an hour away
Old Mar 14, 2009 | 09:10 AM
Fat Ping Cat's Avatar
ah, i just installed springs this past monday. you might want to take the time to calm down and just set aside time to take everything back off the car and reinstall it again making sure everything is where it is supposed to be and that everything is torqued correctly. i didn't screw around with this because you don't want to be worried about your suspension when you're doing 75 down the interstate. you can even get a torque wrench from sears for $25 0 to 75 ft/lbs. All of the springs should have the logo and numbers facing up.. as for the rear this should still apply unless the factory messed this up. you want the part of the spring with the coils closest together on the top (this is the progressive part of the spring) good luck!
https://www.fitfreak.net/forums/fit-...07-08-gd3.html
Updated tutorial on installing lowering springs
How To: Install Skunk2 Lowering Springs for Honda Fit
Tofuman's DIY is excellent!
Old Oct 18, 2009 | 07:47 PM
sbualuba's Avatar
im having the same problem... i installed the all so you can read the words but, there moving everywhere!!!
savage5
Mar 16, 2013 09:16 AM
ricks0slick
Oct 27, 2010 01:04 PM
JIBBZ2
Mar 14, 2009 10:20 AM
omg09fit
Dec 8, 2008 08:19 AM
michaelfit84
Aug 19, 2006 11:24 AM
