Some advice please?
Old Mar 18, 2009 | 06:44 PM
ASquared150's Avatar
Some advice please?
OK, so I've realized that an exhaust upgrade is a cheap way to get some good improvements in terms of torque and hp. I've been looking around this forum for a little while now though and I'm pretty confused. The mix-and-match of parts to create a very customized sound and performance is a lot to handle for a newb.
What I'm asking then is that someone with more experience help me find the right parts to get what I'm looking for:
A boost in performance in the low to mid-range (preferrably low) of the powerband.
Relatively inexpensive (take that as you will...)
Not excessively loud or eye-catching -This is a daily driver and I don't like being pulled over haha.
Cat-Delete is NOT an option as I live in Chicago and it is illegal.
I already have the AEM CAI, so a system that would work well with this would be nice.
Easy installation would be nice but doesn't matter THAT much.
Thanks so much to everyone who responds to help.
-Aaron
Old Mar 18, 2009 | 07:18 PM
GD3_Wagoon's Avatar
aspec header and either an apexi world sport 2 or tanabe touring medallion axleback and you're done. quiet enough to stay below 100db and you can find these items used in the classifieds forum relatively easily
Old Mar 19, 2009 | 03:05 AM
thanks, chaaree. do you think you could elaborate alittle bit on your selections, in terms of why you chose? thanks
Old Mar 19, 2009 | 03:17 AM
GD3_Wagoon's Avatar
no problem dude! the aspec header because their owners seem very happy about it and the gains sound on par with the t1r response header [mainly mid range] but costs much less.
as far as the exhausts go, you can't go wrong with either version. i have the world sport 2 and it's nearly silent at idle and still under 93db even at WOT - i actually hear my engine more than the exhaust itself LoL. same goes with the tanabe touring medallion - except this exhaust is packed and the world sport 2 is a chambered exhaust.
Old Mar 19, 2009 | 10:40 AM
what are the differences between a packed and chambered exhaust? Also, WOT?
Old Mar 19, 2009 | 12:16 PM
GD3_Wagoon's Avatar
WOT = Wide Open Throttle. essentially, pedal to the metal
the difference between a packed and chambered exhaust is exactly that. a packed exhaust uses packing material to muffle the sound output and a chambered exhaust has a series of walls inside the muffler body that dampens the sound.
Old Mar 19, 2009 | 12:55 PM
thanks for all your help chaaree. I think I'm probably going to end up going with this set-up. Thanks again!
Old Mar 19, 2009 | 01:34 PM
GD3_Wagoon's Avatar
glad to have helped
Old Mar 19, 2009 | 02:29 PM
Sugarphreak's Avatar
Push My Button
Ditto for the T1R 50S exhuast, B-pipe and header combo. Sound was very reasonable and not loud when I ran this setup. I kept the scilencer in, lots of people complimented how nice it sounded when I really opened it up on the autocross course.
Old Mar 19, 2009 | 02:32 PM
solbrothers's Avatar
you will lose torque if you do a catback/axleback
Old Mar 19, 2009 | 03:14 PM
GD3_Wagoon's Avatar
you will only lose torque if the diameter of the exhaust pipe exceeds the amount of exhaust gas the engine can produce. a 50mm diameter pipe on an NA L15 is just right IMO
bensenvill
Apr 1, 2014 11:09 PM
Loevess
Sep 21, 2010 02:04 PM
Loevess
Sep 20, 2010 03:23 PM
rpboy06
Jun 2, 2008 07:50 PM
Brad_again
Mar 31, 2007 02:07 AM
