Legitimate coilovers
Old Mar 21, 2009 | 12:10 PM
  #41
sl0wp0k3's Avatar
just another idea to test out...and increase oversteer if needed.
also a question about brake pads...Are they the same as the base RSX front pads?
Old Mar 21, 2009 | 08:31 PM
  #42
SHG_Mike's Avatar
well it wont increase oversteer if you add stiff enough springs to keep the same roll resistance. Remember you need to change the f/r ratio of roll resistance to change how much a car over or understeers.
yes they are... if you check out tirerack they have various hawk pads listed for the fit. HPS HP+ blues etc.... HPS are great for the street and autox HP+ are streetable if you want to track your car and blues are just for track.
Ive personally always used hawks, and we only use hawks on our racecars at work
Old Mar 21, 2009 | 08:37 PM
  #43
solbrothers's Avatar
i love mike.
Old Mar 23, 2009 | 03:27 PM
  #44
sl0wp0k3's Avatar
do you use rear shims and/or front camber bolts for alignment? what are you alignment settings? factory specs is about 1/8 inch toe in for the rear with 1/8" tolerance. would you recommend using shims to alter alignment? or does this weaken the rear hub assembly?
after replacing exhaust/intake is it best to use an air/fuel controller? or is an ecu reset enough?
Old Mar 27, 2009 | 08:54 PM
  #45
sl0wp0k3's Avatar
where did mike go?
Old Mar 29, 2009 | 09:38 AM
  #46
SHG_Mike's Avatar
sorry lol, I/E stock ECU is fine. I use front bolt and eventually will get rear shims, no ill side effects from that. I have what ever the factory toe/camber in the rear, and -2* camber in the front 1/16" total toe out. 1/32" on each side.
Old Mar 29, 2009 | 04:41 PM
  #47
Scratch&Dent's Avatar
Mike is right. All you'll need to do is let the computer relearn the idle trim by letting it idle for 5 minutes (then rev it a few times, perhaps). In some cases you may need to disconnect the battery first. I have replaced my intake, catback, and header and that's all I did.
Old Mar 29, 2009 | 07:51 PM
  #48
sl0wp0k3's Avatar
anyone try 225/45/15 tires up front? what offset wheel? any rubbing?
Old Mar 29, 2009 | 07:55 PM
  #49
SHG_Mike's Avatar
will not fit unless you have flares.... 205 r comps with 2.5* of camber was a stretch
Old Mar 29, 2009 | 07:57 PM
  #50
sl0wp0k3's Avatar
what offset wheel were you using?
Old Mar 29, 2009 | 08:34 PM
  #51
SHG_Mike's Avatar
+38... buy any higher you risk rubbing on the inside on the strut
Old Mar 29, 2009 | 08:37 PM
  #52
sl0wp0k3's Avatar
so...if your ride height was higher, would you still have problems?
Old Mar 30, 2009 | 08:30 AM
  #53
SHG_Mike's Avatar
it would be better but i also had rolled fenders. I would just go with a fat 205 like the R1R
Old Mar 30, 2009 | 03:42 PM
  #54
sl0wp0k3's Avatar
i just autoxed yesterday...i've been doing this for 2 years, and it's still so much fun. only equipment are tires (star spec 195/55R15) and rear anti-roll bar.
i got first in my class (ST) out of 6. 16th pax, 23rd raw out of 100+
i ran a 78.312 (really long course ^_^)
for reference:
#2 nationals d-stock ITR last year got a 75.860
s2k 72.615 (FTD) (had a 71 flat dirty)
fsp protege 72.903 (FTP) (had a 72.3 dirty)
nationals stx bmw 325: 74.642 (had a 73.2 dirty)
nationals HS mini: 78.071
from what i can see and what i've heard is that there's a sub-73s time out there for an ST civic...
if any time was left out there for me, it was probably less than half a second. with such a long course it was almost inevitable to hit a cone somewhere sometime...lucky for me my fastest run was clean
the fit is too soft for ST as of now...i definitely need more responsive suspension, going so fast through the course, the suspension can't keep up with the really fast wiggles, suspension would let me trace much more precise lines.
i also need more front tire and/or camber, with the inside rear lifting, i am still understeering in sweepers.
i hate how i can't do anything to my car at the moment...need...money...
Old Mar 30, 2009 | 06:56 PM
  #55
SHG_Mike's Avatar
congrats... what region were you at? was the protege purple? Thats a pretty good time considering your basically an HS car, with a sway, but your also on street tires when you can run r comps in HS.
an ST Ef would def run in the low 70's if the fsp and AS s2k's were running in the 72's
With strut type suspension, you want as much camber as you can get, so start there
Old Mar 30, 2009 | 06:58 PM
  #56
sl0wp0k3's Avatar
yea protege was purple....i heard he was beating jinx's fsp eg civic...
st is supposed to be slower than fsp according to pax.
this is a local event...scca is too expensive for me
Old Mar 30, 2009 | 07:48 PM
  #57
TheImmortal's Avatar
shims would theoretically weaken the rear hub..i've had no probs removing rear toe using shims and i track my fit and haul cargo
Of course it is "BEST" to use a/f controller...it's all about cost vs gain ratio..if money was no object, of course a/f is "BEST" but could YOU feel a difference?
Old Mar 30, 2009 | 07:50 PM
  #58
sl0wp0k3's Avatar
well i don't really care about 'feeling' the difference, it's all about times...
to be honest, i can't feel the difference in power on course with a celica gts vs. my fit...
Old Mar 30, 2009 | 07:57 PM
  #59
hot bits make coilovers for jazz....oh by the way they r REAL coilovers that can be bought with independent compression and rebound control, external reservoir, and helper springs, they r rebuildable too...u don't want to know how much they cost but if u want that kind of performace, cost is no object hint: price comparable to FI
Old Mar 30, 2009 | 08:00 PM
  #60
for reference:
i'm confused....same track config?
definitely diff track conditions
