do you use rear shims and/or front camber bolts for alignment? what are you alignment settings? factory specs is about 1/8 inch toe in for the rear with 1/8" tolerance. would you recommend using shims to alter alignment? or does this weaken the rear hub assembly?
after replacing exhaust/intake is it best to use an air/fuel controller? or is an ecu reset enough?
__________________
guess what?!? my Fit is USDM!! and STOCK!
