Rear Hatch Trim Panel & Center Console Removal
Old Apr 8, 2009 | 12:03 AM
vwli's Avatar
I have been doing sound deadening on my MT Sport Fit. Anyone know how to remove center console and rear hatch trim panel? I am going to have some sound deadening material left over from doing the doors. I might as well make good use out of it.
Old Apr 8, 2009 | 01:04 AM
aenokea's Avatar
The center console is pretty easy to take out. I installed the center armrest and had to remove the console to get it done. The instructions can be found on the college hills website (collegehillshonda.com). Look for the center console accessory for the 09 Fit and the instructions are linked.
Old Apr 8, 2009 | 12:29 PM
reako's Avatar
Old Apr 19, 2009 | 10:59 PM
vwli's Avatar
Still no one has any idea how to remove the rear hatch trim panel yet?
Old Apr 19, 2009 | 11:21 PM
Fat Ping Cat's Avatar
pull really hard
Old Apr 19, 2009 | 11:37 PM
vwli's Avatar
Originally Posted by Fat Ping Cat
pull really hard
There are no hidden screws?
Old Apr 19, 2009 | 11:54 PM
haha i don't really know as i have never taken it off. i believe there may be one screw inside the part you stick your hand in to close it and everything else is just clips that snap. I've heard they're really easy to break too. try a search, there is probably a detailed DIY on this site for that
Old Apr 20, 2009 | 12:02 AM
theloxmyth's Avatar
Fit Gadget Freak
You'll see, these three items need to come out before you pull hard to remove the trim panel. It simply has clips holding it in, besides for these three things!
The white clips are all that hold it in, once you remove the three items.
Old Jun 14, 2009 | 01:49 AM
euge65's Avatar
That's for GD. Does anybody know how to remove the hatch panel for GE8?
Old Jun 14, 2009 | 09:04 AM
Tork's Avatar
You will see two slots to stick a flat blade screw driver to remove the grab handle.
Then with a flashlight located ones closest to the handle, started pulling the closest plastic studs. The first ones were quite difficult so I used s large flat blade to help pop them. It also helps to pry up on the bottom if the hatch cover (it does bend) to help see where the plastic studs are. After you get about 4 loose it finally starts to get easier to pop the rest.
Hope that helps!
Old Jun 14, 2009 | 09:11 AM
euge65's Avatar
kisses Tork!!!
Old Sep 15, 2009 | 01:19 AM
Shingkyo's Avatar
Hi all, I tried to remove the center console, but I have some little problems here...
Whereas in step 5 indicated in the manual from collegehills, the center console cover (small piece with 3 tabs), could not be removed. I pried open from side using a plastic ruler and I only managed to remove the front of it and its back is still stuck underneath. Isnt it that I just pull if off by force and it will be removed? Also, how to remove the 2 front clips at side???
Old Sep 15, 2009 | 11:38 AM
12vltfrk's Avatar
the two front clips, the ones close to the fire wall and on eather side are the screw type. you use a screw driver to start them then you pry them out.
Old Sep 15, 2009 | 08:29 PM
Shingkyo's Avatar
Thanks for your reply. Can I check with you how to remove the center small cover near to the handbrake handle there? It is indicated to have 3 tabs in the guide.
Old Sep 16, 2009 | 10:55 AM
M4psycho's Avatar
Just take a small flat head screw driver, pry it up a bit and then yank it off. You won't break it. You might want to be a bit careful that you don't scratch the plastic though. If you don't think you can be gentle enough then use a small cloth over top of your flathead.
Old Sep 16, 2009 | 11:01 AM
Shingkyo's Avatar
Thanks man. May I know pry up from which side of it (22 or 33, refer to the below )? The one near to the handbrake or the other direction?
111111111 22 33 444
Handbrake (Cover) Gear
Old Sep 16, 2009 | 11:08 AM
M4psycho's Avatar
111111111 22 33 444
If I remember correctly there's a small inset tab/hole where you can stick your screwdriver into, and I believe that's 33 on your depiction.
Old Jun 30, 2010 | 11:42 PM
Koi's Avatar
Koi
Edit: wrong thread
YourConfused
Mar 24, 2017 04:11 AM
robs
May 15, 2015 03:33 AM
itdontfit
Mar 2, 2013 09:29 PM
damatick
May 26, 2011 10:56 PM
InigoMontoya
Mar 13, 2007 09:11 AM
