Weird Problem... help please?!
Old Jul 10, 2009 | 09:02 AM
GravityFit's Avatar
so i have this weird problem when i just installed my 4 channel amp i installed it perfectly and it works perfectly with my driver side door open but when i close it i get this ugly buzzing sound only from that one door but when i open it its perfectly fine any one have a clue whats wrong?
Old Jul 10, 2009 | 12:45 PM
MetalHead88's Avatar
that is wierd.....
is it like a feedback kind of sound?? if theres a mic for the bluetooth, this could possibly do it if somethings wrong with it.
check your connections for the wires for driverside door speakers and your grounds. make sure you have enough wire to the doors, maybe somethings pulling when the doors shut.
when did this start? when you installed the amp? what equipment did you have before the amp?
keep us updated. also id try posting something up on caraudioforums.com those guys have always been a huge help for me.
Old Jul 10, 2009 | 04:50 PM
GravityFit's Avatar
the problem started a day after i installed the amp and there is a mic for the bluetooth, but i dont think its feed back ill go check that in a little.
My grounds i have the kit Kicker PDK1 which uses a d block for a power and one for a ground my amp i recently put in was a 4 channel Boston acoustic GT-475 and ive had a Fusion 600w for my sub which doesnt distort or anything so im not really sure if its my grounds i have to go check that.
Thanks man!
Old Jul 10, 2009 | 10:47 PM
Gffy2334's Avatar
If it's as simple as door open = good, and door closed = bad then you would do well to re-run the wire, and /or check that the wire is not pinching anywhere when the door is closed, either way it shouldn't take too long to check near the door panel. and even splice in a section of wire if you happened to run it under carpet or something.
Old Jul 11, 2009 | 03:42 PM
GravityFit's Avatar
well its more like door open at a certain point is ok and anymore open gives a squeal and i have plenty of wire for it also if it is pinching what sound would it give me?
and its not feed back from the blue tooth just tested it.
Old Jul 13, 2009 | 12:46 AM
Fluffywings's Avatar
Unhook the speaker wire from you amp and measure the impedance with your door closed and open. If you see a difference there is a wire problem.
Old Jul 13, 2009 | 12:51 AM
U donno Jack fit's Avatar
yeah thats what i'd do ^^^^^ try turning off your dome light - see if that changes anything, it could have to do with the ground for the dome light
Old Jul 14, 2009 | 05:40 PM
GravityFit's Avatar
hmm well after opening the door and inspecting the contents of inside the door apparently one of the clips holding the wire to the doors was unhooked and was being pushed away by the metal guidance rail so it was as easy as zip tying it back to its original spot kinda weird though because it didn't seem like it pulled on the wires when i traced it back to the fuse box area but it works so I'm not complaining thanks a lot though guys lol.
Clouds
Jun 29, 2013 10:27 PM
Blackout
Jul 8, 2009 02:06 AM
terra
Jan 28, 2009 10:42 PM
itfits12
Dec 18, 2007 09:35 PM
3906brad
Nov 17, 2007 01:58 AM
