SPC camber bolt / shim help !!
Old Jul 16, 2009 | 07:07 PM
FELIXY69's Avatar
hi guys, looking to do some camber again !!
for the front, IF my coilovers are slotted for camber already, and at max camber i only get 1.8".......if i add the SPC camber bolts (1.75") does it mean at MAX i can get 3.55" degrees ? OR ARE the SPC bolts are ONLY for "NON SLOTTED shocks ???
as for the shim, since it is a full circle, which means it will push the wheel out at the same time giving camber, how thick is the shim ? and can i double them up ?
using 2 and get 3 degrees of camber ?
Old Jul 16, 2009 | 10:36 PM
nxtfit_08's Avatar
i belive you can do that on the front i havent tryed it yet but as for the shims they are soft plastic and theyre usally used for toe i dont know if you can use them for camber but you may be able to use them though also be careful on the shims the can mess up the abs since you have a sport it will mess with it
Old Jul 16, 2009 | 10:48 PM
BlueCell's Avatar
Does anyone have a solution for the rear camber besides these plastic shims?
Old Jul 17, 2009 | 01:27 AM
Spooling's Avatar
i have a set (SPC front camber bolts) installed with Skunk2 Pro-Cs...
also have the shims for the rears but will install them later along with rear disk brake conversion
Old Jul 17, 2009 | 08:44 AM
FELIXY69's Avatar
what is the max from camber you can have now ?
Old Jul 17, 2009 | 08:52 AM
FELIXY69's Avatar
i just watch the you tube vid on the camber bolts by SPC...it saids they are NOT designed to be used with elongated bolt holes...
Old Jul 17, 2009 | 10:14 AM
Jodele's Avatar
3 shim sets on one rear axle
I've done 1-1/2 shim sets...but you need longer bolts. Take a look at my profile, I have pictures posted there. I've split one set in half and put 3/4 degrees on the top on both sides. Then I followed their instructions. Each shim is about 1-mm thick, so I've added about 3-mm to each side on my car...that is why you need longer bolts.
Old Jul 17, 2009 | 02:51 PM
Jodele's Avatar
3 Shims installed
Old Jul 17, 2009 | 10:15 PM
Spooling's Avatar
It's max'd out on the SPC bolts so it would most likely be -1.7?
need alignment done
Old Jul 21, 2009 | 10:15 AM
FELIXY69's Avatar
need alignment done
1.7 is nothing...i am looking at -5 !
Old Jul 21, 2009 | 10:38 AM
Jodele's Avatar
You're f&#$%ing nuts! Why would you want to ruin such a great little car?
And besides, it will look like it’s been squashed.
whitefitsport
Oct 2, 2018 10:54 PM
ciref8
Oct 17, 2014 12:31 AM
illest.GD3.JB.squad
Aug 7, 2010 05:04 PM
flushge8
Hawaii Community
41
Feb 17, 2010 01:25 AM
nealy
Sep 15, 2009 10:57 PM
