Just picked up ASPEC CAT DELTE... Need installer...
Old Jul 19, 2009 | 12:52 AM
setter11's Avatar
Help with ASPEC CAT DELTE...
I live around Pasadena, Glendale, San Gabriel, Alhambra...
If you can do the install, please let me know and how much...
Or HELP with advice:
How do i get a wrench in from the bottom to loosen the bolts
that connect the cat-delete to the headers? Because it is a
small place to work in...
Some info...
Car is dropped on DF210's so maybe a little hard to get under the car...
Thanks...
Old Jul 19, 2009 | 05:36 PM
MNfit's Avatar
your doing a cat delete on a cali car? Don't you guys have inspections and emition testing you have to do?
Old Jul 19, 2009 | 05:41 PM
setter11's Avatar
uhhhh hmmm.... haha...
we do...
Old Jul 21, 2009 | 03:19 AM
Koi's Avatar
Koi
Are you saying you're trying to do this w/o jacking the car up?
I don't recall ever having problems reaching the spring bolts that attach the cat to the header.
Old Jul 21, 2009 | 04:17 AM
revd34's Avatar
we do have inspections but for new cars i think we don't have to get tested for like 3-4 years and every two years after.
Old Jul 21, 2009 | 04:44 AM
setter11's Avatar
oh no, that would be stupid! Lol...
I cant break the bolts, those bastards are on there good!!! Lol
and i can get to them, but once again having trouble breaking them
and getting my ratchet in the space....
exactly...
Old Jul 21, 2009 | 06:59 AM
Koi's Avatar
Koi
Soak in PB Blaster, then use something for leverage like a breaker bar. I think I used a vacuum cleaner extension tube around my ratchet haha.
Old Jul 21, 2009 | 09:31 AM
Fitting's Avatar
^ do what he said.
Inspepction is a long way away and you can always put the cat back or slip some money to pass.
I would be more worry about how loud it's and getting pull over for that.
Old Jul 21, 2009 | 02:01 PM
koolkevin1107's Avatar
I can do it at my house. It's easy u gotta get under the car and get the car jacked up all the way. When i installed jamesbizzles cat delete, i was WAY under the car. Took 25 minutes after that. It's all about having the right tools and extensions. =]
Old Jul 21, 2009 | 06:21 PM
setter11's Avatar
Nice! do what you gota do!!! haha...
Originally Posted by Fitting
^ do what he said.
Inspectionis a long way away and you can always put the cat back or slip some money to pass.
Ya, its not for a while thats why i want to get that bad boy on there now...
Yeah, so lets say i had to throw that cat back on and i went to smog i wouldn't pass???
haha... so kev how much and when? lol...
yea im lacking the stuff you need...
Old Jul 24, 2009 | 10:48 AM
Fitting's Avatar
When u smog and if they do the visual inspection and see no cat u will not pass. That's why u put the cat back on before heading in for inspection.
Old Jul 24, 2009 | 12:17 PM
saiko's Avatar
Avid FitFreak Poster
Not a very difficult install IMO. Just get a long as extension and you're good to go ... but you gotta get your car on jackstands
Old Jul 24, 2009 | 12:18 PM
saiko's Avatar
If you're baller, or you know someone, they can just pass it for you
Old Jul 24, 2009 | 03:22 PM
setter11's Avatar
ya i go the bolts off the cat by the o2 sensor... And i got one bolt off of the connection to the headers, bu i couldnt get the other bolt off and i couldnt getthe o2 sensor off i dont have a wrench that fits the nut...
Sooo Mr. Baller, where do you go? Haha..
Whats the penalty for having a test pipe in the even i ever get pulled over and checked? I was thinking of just puttin the heat shielding around the test pipe to make it look like one is on there...
Old Jul 24, 2009 | 07:34 PM
Koi's Avatar
Koi
I'm not sure about the specifics but from what I've heard, could be thousand(s) of dollars in fines, or even getting the car impounded.
Seems to be somewhere around $1500 penalty from CA, possible fines up to $2500 from the Federal government, as well as getting your car impounded.
Old Jul 24, 2009 | 07:53 PM
setter11's Avatar
geez!!! thanks...
is it worth the couple HP gain? lol
NOT!!!
dewthedew
Florida Community
Nov 15, 2009 01:44 PM
07fit12
Jan 4, 2009 12:13 PM
GROC80
Apr 30, 2008 09:49 PM
