GTSpec NEW Parts! Crankshaft Pulley and STB
Old Jul 16, 2006 | 01:26 PM
gettinafit's Avatar
Finally We're back up!!! I've had these parts since thursday!! Couldn't post them till today!
There is a company GTSpec here on long island, THey Import aftermarket parts developed and manufactured in Asia, they test fit them (On my Fit!!) And they re-name it with their US Name GTSpec! (Plus some of it may be made in-house)
They tested ALL JDM PARTS! Here is the low down of what Fits so far! The Front Strut Tower bar, Rear Strut Tower Bar, Rear Trunk Cage, Front Lower 2 point Tie bar, And Crankshaft Underdrive Pulley!
For my testing they tossed me the Crank Pulley for $0! 7075 Aluminum (It is the Summit Pulley made in Taiwan that someone else on this board has. Now it's comming to the US via GTSpec MUCH MUCH Cheaper! ) Look for it at a performance distributor near you! retail $140 - $200 (not defined yet) Depends on import tax and shipping.
I am waiting for GTSpec to send me all of their pics they took, but here are the pics of the parts i personally got from them!
Crankshaft Pulley
New Pulley as weighed by "Jimmy101" is (1lb and 6.2 oz) Where the stock is 4 times the weight! at (4lb and 13.2oz).
Results are MUCH BETTER low-end Torque and Better throttle response! Finally some power off a light! Top end has improved slightly as well!
O.k. now here are the pics of the GTSpec Strut Tower Bar!
Retail for the Bar should be priced from $160 - $220. (Not Defined yet)
All i cna say is the quality is Great, and the performance is great!! Really Sticks in high speed Turns!
Hope you like the pics, Look for GTSpec at a Performance store near you, or tell them to Buy from GTSpec in Deer Park, N.Y.!
Old Jul 17, 2006 | 01:15 PM
azkikersfit's Avatar
hey bud,
do u have a MT tranny or AT ? cos im pretty interested in the pulley and i was wondering if it would work on the AT 1.4 idsi engine 2004 model?
is there any gain in HP im hoping if u can hook me up with one, i just got the HKS intake and its pretty good
Old Jul 17, 2006 | 07:42 PM
gettinafit's Avatar
It should fit all L series motors!
Old Jul 18, 2006 | 09:01 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
got a link to their site? id like to check em out and know of any projected date of avaliablity?
Old Jul 18, 2006 | 11:52 AM
gettinafit's Avatar
www.gtspec.com Ask for Mark!
Old Jul 18, 2006 | 04:12 PM
gettinafit's Avatar
to "azkikersfit" Mines is a M/T but it doesn't make a difference with he pulley!
It fits both A/T's and M/T's!
Old Jul 18, 2006 | 06:23 PM
did u feel any difference in HP or any gains? wat are the side effects of the havin this pulley will it affect the engine in a bad way?
Old Jul 18, 2006 | 10:02 PM
gettinafit's Avatar
HP gains on paper are unknown unless a dyno test of a stock one and mines were done, and that's up to GTSpec or SUmmit! THe way it feels as for a feeling of increased power, there definately is! I used to engage 1st gear and step on the gas and it would slowly wind up and then open up at 4500, Now it's got some responsive-ness! Picks up faster, and screams in the top end too! As for harm to the engine, I haven't seen a pulley blow a motor before, but if there ever was any adverse effects, i'll just slap the stock one back on, then tow it to the dealership for free warranty work! But like any other performance part you add, it's against honda's will!
Old Jul 18, 2006 | 10:24 PM
sillypuddy's Avatar
Someone that Posts too much
that's fraud.. YOU broke the engine and YOU want to screw honda for YOUR mistake..
-joe
Old Jul 19, 2006 | 09:22 AM
sLiVeRwOrM's Avatar
FYI AJ has a pulley avaliable now too! hehe.
Id really like to see some dynos for this product.
Old Jul 19, 2006 | 09:29 AM
sLiVeRwOrM's Avatar
wow, thats a nice trunk brace.. I have yet to see one of that type
Old Jul 19, 2006 | 11:52 AM
gettinafit's Avatar
I'm waiting for pics from MARK at GTSpec with the brace in my car to show you guys...... comming eventually!
Old Jul 19, 2006 | 12:02 PM
gettinafit's Avatar
Here's the trunk brace in my car!
Sorry the liner is up, and you are looking at my spare! It was just a quick test fitment!
Here we go!
Old Jul 19, 2006 | 12:03 PM
gettinafit's Avatar
If the full trunk brace is not desired, you can just purchase the rear strut tower bar! (the top bar in that last pic!!)
Old Jul 19, 2006 | 12:50 PM
sillypuddy's Avatar
will the floor sit flat with the full trunk brace?
-joe
Old Jul 19, 2006 | 01:11 PM
gettinafit's Avatar
Just needs a little cutting of the carpet will close snug!
Old Jul 23, 2006 | 12:01 PM
garett's Avatar
so my question is this... has the pulley modification increased your gas mileage any?
also, from the pictures, it looks like a pain to reach the pulley. did you have an issue with fitting your arm in there at all?
Old Jul 23, 2006 | 03:09 PM
sillypuddy's Avatar
Originally Posted by claymore
Guys, found this very good article that has the answers to your questions on lightweight crank pulleys. BTW the fit comes under the does not have a harmonic balancer classification. It's a long read but has good information.
http://www.unorthodoxracing.com/faq_pulleys.html
UR makes pulleys.. of course they will tell you they don't do any damage
-joe
Old Jul 23, 2006 | 09:46 PM
Jimmy101's Avatar
Old Jul 23, 2006 | 11:16 PM
gettinafit's Avatar
no problem accessing t he area for install. no need to even raise the car.
Just turn wheel right and remove the splash shield. then adjust the alternator adjustment to loosen the belt. Then remove the belt from the crank pulley. Then using a 19mm socket and a 1/2 in impact gun, remove nut and remove old pulley and replace with new one! Installation is reversal of removal!
Hope it helps! The view from up top is just a vie from up top! no need to go through there!
