Autocross Pics & Results!
Old Aug 10, 2009 | 07:34 PM
Sugarphreak's Avatar
Push My Button
So Autocross was a blast; check out some pics I took. I couldn't shoot myself so I will have to wait until somebody else puts up some of me
Anyway, I am currently in 3rd place for the rookie championship which is cool There is an S2000 CR with R-comps in the lead & a Cooper S in second.
Pics
Image hosting, free photo sharing & video sharing at Photobucket
Old Aug 10, 2009 | 07:56 PM
HondabRiTT's Avatar
sweet pics =]
Old Aug 10, 2009 | 11:01 PM
Push My Button
Hey ET, how do I adjust the camber on my wheels for a better bite?
Originally Posted by HondabRiTT
sweet pics =]
Thanks!
Old Aug 10, 2009 | 11:02 PM
FLFIT239's Avatar
im jealous i wish i was there
Old Aug 11, 2009 | 08:44 AM
Mr_ET's Avatar
Thanks!
That's a tough one on a fit it would probably have to be a camber plate at the top of the suspension tower in the front and in the rear I'm guessing some washers between the drums and suspension assembly.
You'd probably need a kit but you probably already have some negative camber because of your drop in the front.
Old Aug 11, 2009 | 12:56 PM
Push My Button
I keep seeing camber bolts or something along those lines being used, not really sure how that works. I would like to get about 2.5 degrees of camber, right now I am less than that for sure.
Old Aug 11, 2009 | 02:59 PM
Mr_ET's Avatar
negative 2.5 is great for r compound rubber but fairly aggressive for daily street driving. It will make the car follow every little rut in the road and will affect it's high speed straight line stability on street tires not meant to handle that camber.
Old Aug 11, 2009 | 10:39 PM
Push My Button
I wasn't thinking a permanent adjustment, something more just for events.
Old Aug 12, 2009 | 08:34 AM
Mr_ET's Avatar
you'd need to align the car everytime on a rack unless you bought your own alignement tools.
Hardcore racers do that but I don't think the Fit has achieved that status yet:P
Old Aug 12, 2009 | 06:33 PM
JDMish's Avatar
I have a set of front and rear camber kits from SPC in my tool box at home.
Was going to use on the Fit but went a different route.
paid 100. looking for half if your interested.
btw those pictures are just so boring...where are the pit shots and some nice aperture shots?
Old Aug 12, 2009 | 10:44 PM
Push My Button
Next event I will get some better pics
How does the kit work Jon? Can I set it just for the event or do I have to get it aligned everytime like ET was saying?
Speaking of which are you coming? They put up the pre-registration already, one on the 22nd & one on the 23rd.
Old Aug 13, 2009 | 11:29 AM
JDMish's Avatar
These have to be put onto an alignment rack to adjust 9the front is a oblonged (spelling?) bolt and the rear is a plate style system (see attached)
I work the 22nd but I'll see what i can do for the 23rd. if not participate for sure attend to spectate!
Old Aug 13, 2009 | 07:43 PM
Push My Button
Interesting, so if I am reading this right I can adjust the front camber whenever I want easily? What about the rear?
I only have those two days left this year for autocross, I don't want to run that much camber on a day to day basis.
Old Aug 14, 2009 | 03:34 PM
JDMish's Avatar
the rears would require pulling off the spindle so that's a little hard to adjust on the fly.
the fronts are a lot easier but I'm not sure how you would calculate the degree's without having it on an alignment rack.
Old Aug 16, 2009 | 01:22 AM
Push My Button
Is it easy enough that we could we set it up this week and then take them off (or adjust the front ones) after the weekend?
Also, one more cool ass pic from that weekend
Old Aug 17, 2009 | 04:12 PM
JDMish's Avatar
OK, that is a pretty good pic, zoomed in so that I'm not looking at cones as a fore ground...
And you could potentially set up the car for the weekend and then reset it to factory after the race just takes a bit of time to do it.
Old Aug 17, 2009 | 07:57 PM
Push My Button
That would work, do you have time on Thursday evening?
Old Aug 18, 2009 | 01:27 PM
JDMish's Avatar
Can't Thursday sorry. I'm the labor for getting the in-laws house ready for their daughters wedding next week and there is a few items on my list
Old Aug 18, 2009 | 04:36 PM
Mr_ET's Avatar
I've done the rear camber kits on Will's black Fit and it's a fair bit of work and we needed to bleed the brakes evertime we took those off as we didn't have enough room to remove everything without the brake line out of the way.
The little allan bolt that holds it all on once the drum is off is also a bitch to remove without stripping and having to drill it out
Old Aug 18, 2009 | 06:16 PM
Push My Button
Hmmmm, I might hold off then. This sounds like too much to get into with only 1 weekend left.
I am leaning towards a full suspension system for next year; any suggestions?
