DIY: How to Stiffen a GD3 Drive-by-Wire Gas Pedal
Old Aug 15, 2009 | 02:14 PM
  #41
secondspassed's Avatar
^Glad it went well. I would be worried later it might slide down the pedal, having seen the other pics of this on a GE. I guess it most likely wouldn't be dangerous, but it could be. I might secure that s-hook where it is, anyway. Looks good!
Old Aug 22, 2009 | 07:05 PM
  #42
Stravos's Avatar
I just did this mod today on my GE8, and so far it's great!
I used a 15/32x4.5x0.041" spring. I think using a longer spring with a bit thicker wire diameter would be better, as this spring is stretched a fair amount at rest.
The install on the GE8 couldn't have been easier; didn't require removing anything. Just hooked the top s-hook to the hole below the diagnostic harness, and the other s-hook sits pretty well right below the plastic piece on the accelerator.
Only thing I would recommend is using something other than shrink tubing to protect the paint. It sounded like a reasonable suggestion, but the stuff I bought could not negotiate the turns in the s-hook. But really I don't see a need for it, as it doesn't look like it will be sliding around any.
Thanks for the idea, polaski!
Old Sep 14, 2009 | 02:32 PM
  #43
Chairman Kaga's Avatar
I'm trying out some 10" mini-bungees as I could not find a suitable spring ANYWHERE. I started with one cord, which was noticeable but not quite as much resistance as I wanted, but two seem to be perfect. Surprisingly they stay put on the pedal, although I think I might Dremel a small notch to keep them in place.
Old Sep 14, 2009 | 02:57 PM
  #44
Texas Coyote's Avatar
Use a cushioned wiring clamp around the pedal rod.
Old Sep 14, 2009 | 03:22 PM
  #45
Or duct tape!
Old Sep 14, 2009 | 03:43 PM
  #46
Honestly, a 1/4 inch cushion clamp used for securing wiring works great.... I did this mod not long after polaski posted it but deviated by using a cushioned clamp and used a smaller S hook through the holes in it.
Old Sep 14, 2009 | 03:52 PM
  #47
Black3sr's Avatar
See my post on the 2nd page - I used a C clamp. Since my last post I have gone to a slightly softer spring.
Old Sep 14, 2009 | 04:16 PM
  #48
What I am talking about is a clamp of the sort that secures brake lines or sheathed wiring to a flat surface... It doesn't matter because it isn't visible but it looks neat to me and I doubt that it works any better than the original design....
Old Sep 15, 2009 | 02:44 PM
  #49
Mr08FiT's Avatar
The best mods for the FIT are the free(cheap) mods for the FIT, I can't wait to complete this and the independant fogs this afternoon.
Old Sep 15, 2009 | 03:02 PM
  #50
doubleR's Avatar
I was thinking about this on the way to work this morning. Instead of having my leg cramp up by constantly having a too-light touch on the accelerator at all times, for under ten bucks I can drive just like any other car, with my foot resting comfortably on the gas pedal.
Old Sep 15, 2009 | 03:30 PM
  #51
Selden's Avatar
I like the idea of a cushioned wire clamp on the accelerator rod, but for the upper end, I think that either a small carabiner or a D-ring with a screw lock would work better than an S-hook -- less chance of snagging something, and completely impossible for the spring to come loose by accident.
Old Sep 16, 2009 | 01:14 PM
  #52
Mr08FiT's Avatar
So I completed this project last night and it truley is a night and day difference. I didn't have to buy a spring since I had the one from my stock mustang seat. I bought two 2" hooks and they worked perfectly.
SELDEN~ Maybe you've seen under the dash and where the upper hook hooks to but I couldn't see any reasonable way to get my hands+tools under there. The "S" hooks work just fine. Thanks for the wright up and great idea.
Old Oct 1, 2009 | 08:07 PM
  #53
chinky's Avatar
Canadian checking in. I couldn't find appropriate springs at Rona, CT, Home Depot, or Princess Auto. I know an earlier poster suggested the 5" one from CT, but the gage of the wire looks like it would add too much tension. By chance, I drove by a Home Hardware on the other side of town that I never noticed before. I picked up a spring 165mm long and 16mm diameter. Sorry about the metric, but that's what it says on the sticker.
Old Nov 8, 2009 | 04:01 AM
  #54
socalsmirff's Avatar
f%$#ing smart! i gotta go to home depot tomorrow! i aint been on here in a while, this is so simple, i feel dumb for not htinkin of this.
Old Apr 30, 2010 | 12:37 PM
  #55
Rad's Avatar
Rad
I just installed this mod today and its really fun, you notice it all the time (or at least when you first install it, lol)
I honestly forget what size i used and my receipt dosnt even say but i think it was pretty close to OP's original size (there were subtle differences)
But yeah, works awesome and i ended up using a D-ring around the pedal since the second S-hook wouldnt slip around it.
awesome mod!
Old Apr 30, 2010 | 02:12 PM
  #56
Still enjoying mine, every day. Haven't had leg pain or fatigue since I installed it. One of these days I want to remove it to remind me how it used to be.
Old May 24, 2010 | 03:54 PM
  #57
Trish's Avatar
cheap and effective
sweet mod big time difference
Old Jun 28, 2010 | 05:43 PM
  #58
Sagittarius30's Avatar
Thanks for this simple yet awesome idea!!
Does the wire diameter determine the stiffness of the spring? I used the 0.47 as suggested but still find it a bit soft for my liking. That being said, my ankle is much happier now!
Old Jun 28, 2010 | 06:42 PM
  #59
Black3sr's Avatar
Try another one then Sag. I started with a 3/8's. Whatever anything is better than nothing. I forget I even have it on now.
Old Jun 28, 2010 | 07:35 PM
  #60
hobbes87's Avatar
try ordering from mcmaster.com. I use it for all hardware stuff that I cant find normally in stores.
