Has anyone done a DIY on a MTF change?
Old Aug 17, 2009 | 12:28 PM
kinosh's Avatar
2008 Fit Sport
The shop manual says to change it at Maintenance Minder 3 (whatever that means in miles). There's a drain plug and filler plug. Checking the level seems easy, draining seems easy, but how do you fill? Turkey baster?
Old Aug 17, 2009 | 03:17 PM
i think redline has those pumps you can use. it's similar to the shampoo pump griot's sells.
or try this new funnel.
Old Aug 17, 2009 | 03:22 PM
or better yet, find something like this...
Old Aug 19, 2009 | 09:07 PM
sonicsc1's Avatar
i had to use two tranny funnels to get the fluid in but i will be useing a diffent method next time haha i jacked up the driver side remove wheel crack the bolt pan lowerd the car drain out then jack up again funnel it in slowly and rebolt think only 1.6 quarts
Old Aug 19, 2009 | 09:21 PM
Buzzbomb's Avatar
I used a funnel with a long flexible tube stuck on the end. It was long enough to get into the engine bay. It was a pain but it worked.
Old Aug 20, 2009 | 12:47 AM
polaski's Avatar
I wish there was a way to pull the VSS easily. That method was always king but on this car it's such a reach.
Will be trying soon. Hopefully I can come up with something creative. I hate side fill plugs.
Old Aug 20, 2009 | 01:05 AM
doctordoom's Avatar
Supervillain
you can also buy a pump with a small hose attached to it. it's very much like the pumps that are attached to ordinary hand soap containers, except larger and with a small hose from which fluid is dispensed. i forget where i got mine from, but it was probably pep boys; you could probably get it at any automotive store though. you just screw it onto the MTF container and stick the hose into the fill hole, then pump lol.
Old Aug 20, 2009 | 04:02 PM
gimme's Avatar
Master FitFreaker
this is a question i dont have the answer for, nor have i seen it....how many quarts should I buy for a manual transmission fluid change?
Old Aug 20, 2009 | 04:04 PM
polaski's Avatar
Book says 1.6 qt for a change or 1.7 if you take the case apart. Round up
I had trouble with my last on-the-bottle pump. The straw going into the quart was about 2" off the bottom so I always had to keep extra fluid handy to take up that space. Good idea though, I forgot about this little contraption.
Old Aug 20, 2009 | 05:57 PM
gimme's Avatar
Master FitFreaker
Thanks Polaski, I appreciate it
vwli
Mar 11, 2016 10:24 PM
evoryne
Mar 26, 2013 10:53 AM
lamyun
Mar 12, 2013 09:18 PM
GC617289
Jul 7, 2012 11:25 AM
mole177
Feb 25, 2011 02:51 PM
