Whats the best tar remover
Old Sep 3, 2009 | 07:44 PM
md8232's Avatar
Our country roads have been oil & chipped recently.
Just my luck I was driving the new Fit that day.
I'd like to give it a good cleaning this weekend, but
need something to get the tar off.
Old Sep 4, 2009 | 12:20 PM
pbz08gd3's Avatar
Clay magic!!!
Old Sep 4, 2009 | 01:11 PM
md8232's Avatar
Is this different than a clay bar?
Old Sep 4, 2009 | 01:31 PM
pbz08gd3's Avatar
theres many different ones on the market now, but i always stick to the good ol blue clay... clay magic
Old Sep 4, 2009 | 02:12 PM
true-grit's Avatar
Thumbs up
I used WD-40! & Elbow grease.
Old Sep 4, 2009 | 03:36 PM
pbz08gd3's Avatar
HARSHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!! spare my clear coat would you pls.
j/k i like the clay because it leaves no residue i washed my car thoroughly then hit it with the clay while wet and got everything off even spots of white paint from a paint can i ALMOST hit but the tires still kicked some on my passenger side
then waxed that sucker to a finish as smooth as an asian booty
Old Sep 13, 2009 | 01:36 PM
for real bad tar marks i use RC car motor spray or nitro cleaner. works amazingly well.
for light tar i just use some spray wax (Griot's SprayOn Wax).
Old Sep 13, 2009 | 02:25 PM
FitPilot's Avatar
WD-40 works great and wont harm the paint. Only problem with it though is that it will strip any wax that is on the paint so you will have to re-apply wax.
Old Sep 15, 2009 | 03:25 PM
most tar removers remove wax so you're good there.
but if you use WD40 you'll need to use some alcohol or RC motor spray to remove the oil before you wax...so it's double work.
motor spray (or RC nitro cleaner) can be found at your local
hobby store that sells RC stuff. or try towerhobbies.com
DeltaBond
Aug 13, 2013 05:03 PM
DaveInWoodland
Oct 30, 2012 07:52 PM
cruiserandmax
Jan 18, 2010 10:44 PM
m-man@sbcglobal.net
Jun 22, 2008 11:34 AM
Rob22315
May 29, 2008 04:33 PM
