installing 3rd brake light
Old Sep 3, 2009 | 07:49 PM
bluefit96734's Avatar
anybody know how to install the led 3rd brake light for the 2009 honda fit sport.
Old Sep 3, 2009 | 09:08 PM
HONDAMATIC's Avatar
come by the meet guaranteed one of us can do it.. try look in your owners manual, it shoud say..
Old Sep 4, 2009 | 07:05 AM
ToyotaFIT's Avatar
wow you're really good at selling the fit meet... you sold me!
Old Sep 4, 2009 | 09:29 PM
sedanimal's Avatar
this is just the dissasembly part, doing this from memory so bear with me. and the third brake light you're putting in should be easy to figure out once you have the whole thing apart;
  • open the hatch
  • take the cover off (two little press-in tabs)
  • unplug white connector plug thingy (you can do this later if it's easier)
  • unbolt two 10mm bolts
  • use a small flat head or something to push the two inner clips in (that are going into the mounting hole between where the two bolts were)
  • for the plug - slide the taped wires to the untaped area so you can get it through the open area of the hole (the assembly should be unattached to the car now)
  • press on the two exposed tabs with a small flathead, when you get both unhooked, just push it out and the two on the opposite side (the top) will come undone
Old Sep 6, 2009 | 08:39 PM
i know how to take the assembly off, it's just where do i plug the little circuit board thing in.
Old Sep 6, 2009 | 11:26 PM
HONDAMATIC's Avatar
if i think its like mine it plugs in where the bulb goes.. like wedge it in there
Old Sep 8, 2009 | 06:46 PM
where does that black piece plug into?
Old Sep 11, 2009 | 07:30 AM
hondafitgow's Avatar
lol. thats for the outlet.. basically you turn it vertically and plug it into the slot where you unplugged the original one... no worries I thought the same thing.. if you never get it just pm me. oh wait well actually thats how it works for the 07-08 models... hmm should be that same... i think
Old Sep 11, 2009 | 01:57 PM
HONDAMATIC's Avatar
isnt the ge one LED already?? maybe you got a gd one
Juliane
Jul 25, 2017 02:35 PM
koolkevin1107
71
May 4, 2016 09:27 AM
07fitsport
May 5, 2009 03:02 AM
dbcmaster
Dec 10, 2007 03:31 PM
pedaler
Jul 6, 2006 11:46 AM
