Rear Night Running Lights broken...
Old Mar 3, 2008 | 09:58 PM
Cazzzidy's Avatar
Hello all,
I am trying to wire my fit for a utility trailer with a T-One kit. I have successfully wired the vehicle, but while diagnosing a problem with the trailer wiring, I think I may have blown the fuse for the rear running lights by shorting the brown lead.
The symptoms are:
No rear running lights when the lights are set to on.
Headlights, brake lights, blinkers, etc. are fine.
No voltage on the brown trailer wire when lights are on.
I checked all the small fuses, and they look fine. Does any one have any idea what fuse this circuit is on? Any other ideas?
Thanks,
Cassidy
Old Mar 5, 2008 | 07:01 PM
Cazzzidy's Avatar
Wow
No one can tell me what fuse handles the taillight circuit?
Some one has got to know! I can't drive at night!
Cassidy
Old Mar 5, 2008 | 09:44 PM
billmus86's Avatar
My Lips Bigger!
so the little top portion of the lights dont work?, and the bottom doesnt light- unless the brakes are on? and then only the bottom lights right? the top never lights up now?
only one i know off the top of my head is #1 is reverse lights, (not that-that helps)
and please maybe? (just kidding)
Old Sep 6, 2009 | 05:24 AM
Black3sr's Avatar
I know this is an old thread but I think I have the answer. A way back in the 60s I was trying to wire my Austin 1100 for my tent trailer. I had similar problems in that could get all the lights working properly but not all at same time.
It turns out you have 3 lights/circuits on the car - brake, running and signal. On the trailer you have two - running and the other is a combo of brake/signal. So I needed to add a small pair of lights to the trailer to act as signal. Geez I spent a day on it before realizing the problem.
Fit4beach
Nov 17, 2021 08:03 PM
omfgitshimm
Oct 27, 2009 11:58 PM
Tranas
Jun 21, 2009 05:23 PM
Guinness
Jul 2, 2008 02:26 AM
kyo2529
Oct 2, 2007 02:12 PM
