What if I install an exhaust header only?
Old Sep 8, 2009 | 03:29 AM
jevin's Avatar
Okay so I have a 2005 GD1 Fit (1.3L i-dsi engine) with stock exhaust and I get a squeaky noise from where the exhaust manifold meets the cat. So I'm thinking of changing the manifold to install a custom made header.
I'm doing this because I feel the manifold is getting old, but at the same time, I'm asking myself if there are any performance gains by putting in a header only. Any advice on what type of header I should get? 4-1, 4-2-1? And what about the diameter of the header? Should I keep it the same or go for thicker/thinner?
Thanks for the help.
Old Jan 13, 2010 | 04:23 PM
elifit07's Avatar
Have you fixed the noise yet? Any luck?
Old Jan 13, 2010 | 06:46 PM
danger69's Avatar
4-2-1 makes more power on the low-hi end. And the 4-1 is good for mid - high end power. Its really up to you.
Old Jan 14, 2010 | 12:58 PM
DatFIT's Avatar
I would go 4-1 ... since the fit takes off pretty fast lol
Old Jan 15, 2010 | 12:29 AM
jevin's Avatar
Nope. Haven't fixed it yet. There's a proper shop that does custom exhaust systems like 50 kms from where I live. I need to go there someday.
Old Jan 15, 2010 | 08:58 PM
redrumm's Avatar
maybe your bolts rusted out and broke or a rubber hanger might have ripped and needs to be replaced. the only way to check is to jack up the car and look
Old Jan 17, 2010 | 06:28 PM
wdb's Avatar
wdb
The T1R Response header is 4-into-1 and boosts midrange performance, although it ain't much truth be told. I notice it on hills at lower RPMs. They spent a bucketload of time getting the design right so it might be a good model for your local shop to start with.
Old Jan 25, 2010 | 07:06 PM
DOHCtor's Avatar
To answer the question. I would say it will net you some kind of a gain but you will leave something on the table!!
Marko!
Old Feb 17, 2012 | 11:50 PM
jeon's Avatar
Okay so I have a 2005 GD1 Fit (1.3L i-dsi engine) with stock exhaust and I get a squeaky noise from where the exhaust manifold meets the cat. So I'm thinking of changing the exhaust manifold to install a custom made header.
Im kindda late with this but the installation will be easier on newer fits for sure in that the bolts shouldn't be too badly rusted though you can still opt to put the header online It can still be done on older cars. You may want to consider buying new bolts for the connection between the header and the catcon.
Old Feb 18, 2012 | 05:54 PM
MNfit's Avatar
I put a new exhaust on my Fit after having it for a year and man where those bolts rusty. All the water the exhaust pipping is exposed to plus the heat cycles it has makes those bolt a PITA to get off
dwtaylorpdx
Jun 22, 2016 05:40 AM
Staff@WR
103
Sep 17, 2008 04:54 AM
Mr08FiT
Sep 13, 2008 06:10 PM
dewthedew
May 9, 2008 03:21 AM
Rocky
May 28, 2005 04:41 PM
