Camera Security System??
Old Sep 12, 2009 | 01:32 PM
BayAreaKid's Avatar
Question Camera Security System??
Anyone install a security camera system in their car? My car was hit while I it was parked and I want cameras to catch this if it happens again. Luckily they left a note, but next time they may not. I was looking for a front and rear camera setup maybe side as well.
Old Sep 14, 2009 | 05:57 AM
CuTeBoi's Avatar
apartment or house?
Put the cameras around the car, if your car gets hit, it will most likely be from the side, the view angles of cameras mounted on a car would be too limited. and with the power supply requirements from systems that have HD quality to "catch" the culprit, your battery would die rather quickly.
Old Sep 18, 2009 | 07:46 PM
interestingstuff's Avatar
NetworkCameraReviews.com - IP Camera Forum is probably one of the best forums out there for security camera info. I would go there and ask for suggestions. I have seen plenty of tiny cameras. Most run on DC. Many run on batteries. It should be easy enough to set up good unit(s) once you figure out what is out there.
Please report back with what you find out.
SilverEX15
Dec 16, 2017 05:46 PM
Press Fit
Sep 17, 2016 07:26 PM
ADVphotography
Oct 27, 2014 11:25 AM
BayAreaKid
Sep 13, 2009 01:22 PM
andyd
Sep 4, 2009 08:29 PM
