Front higher than rear?
Old Sep 15, 2009 | 09:58 AM
mkht78's Avatar
Hi, Just lowered my car on some H & R springs on a set of 16'' alloys, the back looks miles lower than the front, does anyone know why this is? or what do I do to rectify it. I've also noticed that above 70mph the car/steering wheel vibrates.. I had a technician to do the job as well so surely its the tyres problem?
Old Sep 15, 2009 | 12:53 PM
dela's Avatar
well the height situation is most likely because thats the way the springs are... i know tanabe dfs tend to have lower rears as well..
as for the wheel vibrations.. did you get your car aligned after you installed the springs?
Old Sep 15, 2009 | 01:16 PM
mkht78's Avatar
Mmkay, cheers for the reply i know it's not good. As for the wheels, yup they were aligned- just a bit annoying at the moment because
of the speed I have to drive them
Old Sep 15, 2009 | 03:06 PM
have your new wheels/tires re-balanced.
Old Sep 16, 2009 | 11:13 AM
GD3_Wagoon's Avatar
if they're aftermarket wheels then you may need hubccentric rings or learn how to properly mount your wheels to the hub. the gd3's hub bore is 56.1mm (took a while to dig that up using the search button)
i'm not running hubccentric rings and my wheel bore is 67.1mm.. i took my time mounting my wheels making sure they've made flush and even contact with the hub and i get no wheel vibrations even up to 80+mph. eventually, i will get hub-rings because it's just that much easier when removing/remounting wheels.
Old Sep 16, 2009 | 11:31 AM
Vanishing Point's Avatar
It does take several days for the suspension to settle after changing springs. Are you sure you don't have the springs reversed, rears in the front and fronts in the rear? Just a thought.
Old Sep 16, 2009 | 03:02 PM
JDMchris.com's Avatar
I run THIS
Depending on the drop of the springs you can get the illusion that the rear is lower. The front wheel well is bigger than the rear, so a even drop will make the rear look lower... Thats why most springs are like a 1.5 front and 1-1.25 rear, to give it a more even look.
Old Sep 16, 2009 | 07:25 PM
mkht78's Avatar
Hmm, cheers for the replys guys! now that is bizarre!
SilverEX15
Jan 20, 2019 11:30 PM
Francheeze
13
Aug 22, 2014 09:57 PM
scrmblr2
Aug 31, 2011 01:35 AM
Rigaman
Aug 27, 2009 09:55 PM
Navin323i
Dec 1, 2007 01:23 PM
