Tire, Wheel, Brake & Suspension Welcome to the FitFreak.net Tire, Wheel, Brake & Suspension Forum
Winter Wheels, steel rims
Old Sep 22, 2008 | 11:04 AM
jeandeau's Avatar
I searched for compatible 14" steel rims and found Geo Storm wheels are the perfect 14" steel replacement. 6" wide with more than adequate clearance of calipers, 56mm center hole and 45mm offset. Half inch wider than stock, they take the 185/65 14 tires very well. I bought my four rims for $5 each. Saturn S models give a 14 x 5" wheel that fits good though it has only a millimeter clearance to the calipers and the 57mm center hole is not perfect but adequate. Saturn advantage is a plentiful supply at the auto wreckers. Acura Integras provide 14 x 5.5" rims that look good also.
Old Sep 27, 2008 | 07:28 PM
dank24's Avatar
any discounts if I buy the wheel/winter tire combo? I need to hook up 2 cars for winter.
Old Sep 17, 2009 | 01:04 PM
jim@tirerack's Avatar
Former Vendor
Just make sure on the load capacity and the offset of the wheels. If I can help with the tires let me know. We do have a rebate through 09/26 on the winter tires.
k-man
Dec 12, 2012 06:21 PM
alower
Jul 10, 2012 01:33 PM
Sabiokah
Apr 20, 2010 05:22 PM
arnenewfit
Jan 4, 2010 05:08 AM
Quartz
Dec 9, 2007 03:55 PM
