When should I change my air filter?
Old Sep 28, 2009 | 03:30 PM
Juliane's Avatar
I've got about 8K miles and my gas mileage is crap right now. Should I change my air filter? It looks kind of grimy but not totally nasty...
Oddly enough there is nothing in the glovebox manual about the air filter.
Old Sep 28, 2009 | 03:47 PM
eldaino's Avatar
interesting i thought there was.
my fits maintenance minder told me when to replace mine. (like at 30k).
so just wait for the maintenance minder to tell you when to do it. i remember reading someplace in the manual that you have to do it every 15k if you live in overtly dusty areas.
Old Sep 28, 2009 | 04:44 PM
SleepyNyte's Avatar
Honda recommends you change it when maintenance minder #2 shows up, or in 15k miles if you live in dusty places. I would recommend you just buy a K&N drop in air filter for $40 dollars on Amazon so you don't have to buy new filters every 15k miles. For ease of use I have listed all the various codes as well as routine care listed by Honda on their owner link website.
If you don't have an account there you should sign up for one. https://www.ahm-ownerlink.com/
Most of this info is also in your Honda Service History Manual you should have received from the dealer when you purchased the vehicle.
Maintenance Minder A Scheduled Maintenance
Recommended service for your 2007 Honda Fit:
Replace engine oil*1
*1: If the message "SERVICE" does not appear more than 12 months after the display is reset, change the engine oil every year.
Independent of the maintenance items in the information display, replace the brake fluid every 3 years.
Inspect idle speed every 160,000 miles (256,000 km).
Adjust the valves during services A, B, 1, 2, or 3 only if they are noisy.
Maintenance Minder B Scheduled Maintenance
Replace engine oil*1 and oil filter
Inspect front and rear brakes
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system#
Inspect fuel lines and connections#
#: See information on maintenance and emissions warranty on page 172 of your owner's manual.
Maintenance Minder 1 Scheduled Maintenance
Rotate tires
Maintenance Minder 2 Scheduled Maintenance
Replace air cleaner element
If you drive in dusty conditions, replace every 15,000 miles (24,000 km).
Replace dust and pollen filter
If you drive primarily in urban areas that have high concentrations of soot in the air from industry and from diesel-powered vehicles, replace every 15,000 miles (24,000 km).
Inspect drive belt
Maintenance Minder 3 Scheduled Maintenance
Replace transmission fluid
Driving in mountainous areas at very low vehicle speeds results in higher transmission temperatures. This requires transmission fluid changes more frequently than recommended by the maintenance minder. If you regularly drive your vehicle under these conditions, have the transmission fluid changed at 60,000 miles (100,000 km), then every 30,000 miles (48,000 km)*2.
*2: Automatic transmission
Maintenance Minder 4 Scheduled Maintenance
Replace spark plugs
Inspect valve clearance
Maintenance Minder 5 Scheduled Maintenance
Replace engine coolant
Honda Maintenance Checks
Keep your Honda running like new. Between scheduled Maintenance Minder items, periodically check the following items:
Engine oil (orange loop dipstick)
Weekly or when you stop for gas. Add oil if the level is below the lower mark.
Engine coolant
Weekly or when you stop for gas. Check the reserve tank; don't remove the radiator cap - the fluid is hot and may gush out.
Windshield washer fluid (blue cap)
Monthly. Frequent users should check each time they get gas.
Automatic transmission fluid (yellow loop dipstick)
Monthly
Brake fluid (large gray cap)
Monthly. Low brake fluid could indicate a problem. Take your Honda to a dealer for service immediately.
Clutch fluid (small gray cap, manual transmission only)
Monthly
Power steering fluid (red cap)
Monthly
Tires
Monthly. Check pressure. Check tread for uneven or excessive wear and foreign objects.
Battery
Monthly. Check condition (level of fluid or color of the indicator). Check terminals for corrosion.
Air conditioning
Weekly. Turn it on for a short time.
Lights
Monthly. Check them all -- head, tail, parking, and brake lights, high-mount brake light, turn signals, back up and license plate lights.
Old Sep 28, 2009 | 05:00 PM
Burbio's Avatar
When it gets dirty.
Old Sep 28, 2009 | 05:10 PM
Juliane's Avatar
I live in an extremely dirty city, so I may just change the filter now. Thanks Freaks!
Old Sep 28, 2009 | 06:18 PM
Edison Carasio's Avatar
I changed mine at like 20k, and replaced it with a K&N drop in. I cleaned that last night, and I have 45k miles.
Old Sep 28, 2009 | 10:26 PM
changing airfilter frequency depends on driving conditions so if you're in a dusty area or have been exposed to wild fires with lots of ash, i'd change it much more frequently than wat the maintenance reminder says.
Old Sep 29, 2009 | 10:35 AM
InternDoc's Avatar
I cant find the filter on Amazon ? do you have the link ? Thanks
Old Sep 29, 2009 | 07:08 PM
SleepyNyte's Avatar
Press Fit
Oct 23, 2017 11:44 PM
mandobaron
May 30, 2015 02:58 PM
Brain Champagne
Feb 2, 2014 04:00 AM
clemsonteg
Mar 1, 2013 04:16 PM
Eugene.Atget
Sep 11, 2012 02:19 PM
