cabin air filter
Old Sep 6, 2017 | 07:37 PM
Press Fit's Avatar
cabin air filter
Is the cabin air filter in the glove box also known as "the dust and pollen filter"? I looked at mine after 10k miles -- it is filthy. I ordered a replacement. Honda recommends replacing the dust and pollen filter at 15k miles -- there is a maintenance minder code for replacing it. Does the maintenance minder sense it needs to be replaced or is it just on a "timer"?
Old Sep 6, 2017 | 07:43 PM
2Rismo2's Avatar
Yes that's the same thing. Obviously it depends on your environment but mine was dirty around 10-12k. If I remember to, I'll pull it out and just shake it out a bit to get the bug bodies or leaves out of there. I just buy the cheapo ones on Ebay or Amazon. Not sure I'd want the k&n replaceable one personally.
Old Sep 6, 2017 | 09:05 PM
sjd's Avatar
sjd
I have the K&N in my Civic Si and it works really well. I clean it and and refresh it every 2-3 months.
Old Sep 6, 2017 | 10:16 PM
Westie's Avatar
I just bought a Fram Charcoal filter online. I too am cheap and on occasionally just pull the old one out, shake it and reuse. But it will def be swapped out at 15k though.
Old Sep 6, 2017 | 11:18 PM
yah, i use the fram charcoal one too. i replace it every 2 yrs.
Old Sep 11, 2017 | 02:30 PM
Press Fit's Avatar
Although my cabin filter was very dirty at 10k, the engine air filter only had a hint of dirt on it. Have others observed this too?
Old Sep 11, 2017 | 03:53 PM
2Rismo2's Avatar
Engine filter has been good for about 15-20k on mine. I've only replaced it twice so far. This last time with a K&N since it was on sale.
Old Sep 13, 2017 | 02:11 PM
2Rismo2's Avatar
Does it have a smell after cleaning?
Old Sep 13, 2017 | 03:59 PM
sjd's Avatar
sjd
The refresh spray has a slight fresh scent when I spray it on the filter but once it's installed I don't notice a thing.
Old Oct 22, 2017 | 05:00 PM
ken.fit's Avatar
In case anyone is searching for an image on how to orient the cabin air filter. The ribbed side should be inserted such that it faces up, with airflow arrow pointing down.
Old Oct 23, 2017 | 11:44 PM
ken.fit's Avatar
For reference just in case someone else buys a non OEM cabin air filter which doesn't have arrows indicating which side goes down. The side with the ribs should be on the top when you insert it.
Pucci
Mar 16, 2013 06:53 PM
Eugene.Atget
Sep 11, 2012 02:19 PM
BlueBlazer49
Apr 26, 2011 07:46 PM
masp
Sep 25, 2010 11:37 AM
Eugene.Atget
May 24, 2009 09:33 AM
