help with wheel and tire fitment
Old Sep 30, 2009 | 10:39 PM
Nick_'s Avatar
hey guys,
i am planning on getting the Konig Runaway on 17x7 +40 offset with goodyear eagle gt 215/45/17.
just want to know if anyone has any suggestions or feedback on that or should i go with different size tires? will they rub?
thank for your help
Old Sep 30, 2009 | 11:20 PM
Type 100's Avatar
That's probably going to rub. Too little offset (+5mm more will be great), too high a sidewall I think. You'll want a 40-series tire.
Old Sep 30, 2009 | 11:33 PM
Nick_'s Avatar
thats what i thought =( will the 205/40/17 work better tho (i got a GE8 if that matters lol)
sorry this is a noob question cus i am new with wheels and all that
where does the tire or wheel rub against? inside the fender? or other parts around the wheels
Old Oct 1, 2009 | 09:56 PM
Type 100's Avatar
Rubbing will happen most likely at the rear fender if you have too low an offset or too wide wheels. If offset is too low the wheel/tire sticks out of the fender. If you have a load of people or cargo at the back that's when the rear fender rubbing will manifest.
205/40R17 should be okay. I have a GD1 and correct offset is more critical on GDs. I think GEs can accept 7"-wide wheels with a minimum of +43 offset without rubbing (any higher offset is also good).
If your wheels are slightly narrower, e.g. 6.5", you can run a little less offset without rubbing - about +38.
Old Oct 2, 2009 | 04:06 PM
Nick_'s Avatar
thanks for helping out a noob, +rep for you!
btw spacers all around or just the rear wheels?
Adam_Melton
111
Apr 16, 2023 10:12 PM
gsx-r35
Jun 9, 2011 01:42 PM
FITProject
May 10, 2011 07:02 PM
SikxChoi
Jan 13, 2010 02:51 AM
Sugarphreak
May 27, 2008 10:50 AM
