Color matching Brake Calipers on GE8
Old Oct 12, 2009 | 05:40 PM
09blackfit's Avatar
Can I hear some suggestions/input from people out there who have painted/color mated their brake calipers? I'm thinking either black to blend in or red to match my red honda emblems. I'm ordering black brake disks and have black wheels. It was either get red tuner lugs and paint the calipers black or paint the calipers red and get black tuner lugs.
I'm not much into applying fake covers or anything that will make them look more like a big brake kit. I think the wheels need a little accent though. The red emblems pop so well off of the my black fit I figured why not make the brake discs recede into the black wheels and make the calipers pop off the disks and through the wheels.
So... any suggestions on what kind of paint? Should I remover the calipers, paint then and then put them back on? Should I just mask them off and paint them? Will this effect my braking in any way?
Any help would be greatly appreciated. Thanks in advance.
Old Oct 12, 2009 | 06:40 PM
FIT_2a_T's Avatar
I think the black and red contrast will have a good and consistent look to it.
I just masked and painted, unless you really have that much free time on your hands or you really want folks to look that close at them.
I'm not that hard on my brakes and just went with a Kryon heat resistant mix to get the shade I needed. There is a base coat that has been discussed in other similar topic threads, try the search feature.
Old Oct 13, 2009 | 02:46 AM
Goodguy-Fly's Avatar
I beg you, do not paint them red. You are calling attention to an economy car's brakes. If you invest in a big brake kit, then you can paint them red--but even then I would go with black.
Old Oct 13, 2009 | 04:57 AM
Black3sr's Avatar
Mine. I am thinking of painting wheels white.Name:  001-1.jpg
Old Oct 13, 2009 | 05:29 AM
vinn's Avatar
white is nice. i was planning on doing that back when i had a taffeta -.-
Old Oct 13, 2009 | 07:35 AM
09blackfit's Avatar
What kind of paint did you use? Krylon heat resistant paint was mentioned above, will anything else hold up? How long was it before you could drive the car after your painted the calipers?
Old Oct 13, 2009 | 07:37 AM
09blackfit's Avatar
Fit 2a T, I've tried doing a search for calipers, brakes, painted brakes, painted calipers, and nothing really comes up.
Goodguy-Fly, I'm sorry my decision hurts you so deeply. Painting them red is merely an aesthetic decision. I need some contrast. It will be fine don't worry. We'll get through this, I promise.
Old Oct 13, 2009 | 10:40 AM
Black3sr's Avatar
I used Duplicolour. It came as a kit. It included a spray can of cleaner and small brush. I forget how long I let it sit. I had to put two coats on and did not have to wait very long to do the second. I had one small spot peel off. I guess I did not clean it properly. I manage to touch it up without taking wheel off.
Old Oct 13, 2009 | 02:00 PM
09blackfit's Avatar
Thanks for the info. I will look for it at autozone/advanced this afternoon. If they don't have anything I'll default to lowes or ace.
Old Oct 13, 2009 | 03:26 PM
blassty's Avatar
Good thread. I'm thinking of painting mine red just so I can add a little color.
Old Oct 13, 2009 | 04:00 PM
09blackfit's Avatar
exactly my point.
Old Oct 15, 2009 | 01:25 PM
jnesselroad's Avatar
the duplicolor engine paint at advanced works great. just make sure you clean everything really well first. i did red on my black ek years ago, held up fine. the most important part of ANY paint job is the prep. spend the most time there.
Old Oct 15, 2009 | 01:56 PM
09blackfit's Avatar
What would be the suggested cleaning method and solvent? Rubbing alcohol with a brush and towels? Some sort of degreaser?
Old Oct 15, 2009 | 02:19 PM
shazaam's Avatar
black with red lugs. red caliper = ...if I can't be fast I might as well try look the part.
Old Oct 15, 2009 | 02:45 PM
gd3vbp's Avatar
Brake cleaner works great, just have to work quick before it dries.
JaySongChang
Jul 29, 2015 05:41 PM
volcom
Jan 1, 2009 10:26 PM
xonexlifex
Sep 17, 2008 12:22 AM
JazzTune
Aug 9, 2008 10:50 AM
Young Roids
Aug 2, 2008 09:41 PM
