Fender Liner Mod?
Old Oct 30, 2009 | 02:26 PM
Special's Avatar
Fender Liner Mod?
Hey All,
Ive been searching for a while now and havent really found much... Plus i'd thought a whole new thread for this would be benefital to others.
Anyone has more info on the fender liner mod (tucking the fender liner up)?
All ive found was that u unclip a couple clips and tuck it up. It would be great if I could get some pics of this too. Anymore info would be great!
All this is cause im rubbing like crazy, small bumps, tighter turns, etc. U turns are a bit of a nightmare.
BTW im on Pro-Cs w/the front tires tuckin about 1/4 inch on 15x6.5 +41 offset with 205 50 series tires.
Thanks!
EDIT: Figured it out when i took off the fender liner. Just had to reverse the order of the liner (tucking it under) Ill post pics when i get some time
Updated w/pics: (sorry for the bad pics)
Before
After
Hope this helps others!
Old Jan 14, 2010 | 11:42 AM
FitnessJay's Avatar
bump!!!!!!!!!!!!!!
Old Jan 19, 2010 | 11:25 PM
imjustbettr's Avatar
bump!!!!!!!
Old Jan 20, 2010 | 02:15 AM
Special's Avatar
sorry guys, i hella forgot about this. And now i lost my SD card with the pics on it. I'll try to get u guys a pic soon
Old Jan 20, 2010 | 11:04 PM
danger69's Avatar
Fender mod is one thing, but you might have to run with a neg camber as well.
Old Jan 20, 2010 | 11:15 PM
Special's Avatar
Updated.
danger; Once i did the mod, i no longer rub too much to the point of having to run a more aggressive camber setting.
Old Jan 20, 2010 | 11:30 PM
Hootie's Avatar
Did you take the two pop tabs out at the top to do this?
I'm going to do this to my Fit, but I don't know if I have to take all the screw/tabs out from above the side skirt to the last tab before the bumper screw or not.
Edit: It seems like you just removed the screw and its plastic clip and I'm guessing the pop tab in front of it.
Old Jan 21, 2010 | 04:00 AM
Special's Avatar
yea, i just took off the tabs/clips closest to the upper portion of the liner. I didnt take off the ones by the side skirt.
Old Jan 21, 2010 | 07:32 PM
accordguyintake's Avatar
i also bent that metal piece in for more clearance.. well actually the tires kinda did so i got it fully outta the way
Old Jan 21, 2010 | 07:35 PM
dewthedew's Avatar
How about I just did a fender liner delete lol
Old Jan 21, 2010 | 07:48 PM
thefit09's Avatar
I was wondering about this^^^ can't this cause some serious problems, at least with the front liners?
Old Jan 21, 2010 | 07:51 PM
dewthedew's Avatar
well, I kinda ran over a large curb... it tore most of the plastic off and I just took the rest off because it wasnt staying it properly. I havent decided what im going to do about it yet lol. Ill probably get the fender liners and the beatrush panel. Only real problem is the tires kick up dirt/water into the engine bay.
Old Jan 21, 2010 | 07:55 PM
thefit09's Avatar
Haha ok, that makes more sense.
UnFitRick
Jul 29, 2018 02:22 PM
jhass
Nov 25, 2017 10:18 PM
mjlive2k5
Jan 5, 2016 03:21 PM
drock305
Apr 7, 2010 12:38 PM
Amageus
Mar 6, 2009 05:44 PM
