Fender Well Liners Rubbing
Old Jul 26, 2018 | 05:14 AM
UnFitRick's Avatar
After lowering my 2019 Fit Sport 1.5in on Eibach springs AND installing 25mm wheel spacers on the rear wheels, I started hearing a little bit of rubbing in the back under heavy suspension compression. I've inspected the tires and I don't see and rub marks, but I did notice that at the top of each rear wheel well, the inner fender well liners don't sit flush to the fender.
I believe this is the source of the rubbing; it looks like under compression the actual tread of the tires is rubbing the "protruding" portion of the fender liners. It doesn't look like the liners are installed incorrectly; it looks like that's just the way they are. Anybody else experience this issue; if so what did you do about it? I will take some pics when I get a chance.
Old Jul 26, 2018 | 07:59 AM
UnFitRick's Avatar
The wheels/tires set pretty nicely, should be okay right?
Here you can see where the fender well liner is not sitting flush.
Here is a close up. The liners on both rear wheel wells are like this...
Old Jul 26, 2018 | 08:20 AM
xxryu139xx's Avatar
Well known gk problem. Rear fender liner sag. Just cut that part out.
Old Jul 26, 2018 | 09:46 AM
Helios's Avatar
LX models don't even come with them. They are only there for sound deadening.
Old Jul 26, 2018 | 09:47 AM
UnFitRick's Avatar
Well, it is well known to me...now. I will be doing some snipping...
Old Jul 26, 2018 | 03:13 PM
DannyJ7's Avatar
I just pulled them both out on back. Get some 3M spray on liner. Does the trick for both sound deadening and rust prevention.
Old Jul 26, 2018 | 03:14 PM
DannyJ7's Avatar
Old Jul 26, 2018 | 04:58 PM
evilchargerfan's Avatar
def no liners in the rear of my lx. meh .... thug life .... cut it off
Old Jul 29, 2018 | 02:22 PM
UnFitRick's Avatar
I trimmed off the offending portions on both sides, and more more rubbing...
However, thanks to my unacceptably loud new exhaust (unacceptable in terms of interior noise levels) I will spraying generous amounts of rubberized undercoating into every nook and cranny of my undercarriage. So, my plan for now will be the remove the liners, undercoat and reinstall the liners.
FWIW, this will be part of a three pronged sound deadening approach which will include 1) the previously mentioned rubberized undercoating, 2) butyl rubber sound deadening mat, and 3) mass loaded vinyl sound proofing mat...
jhass
Nov 25, 2017 10:18 PM
mjlive2k5
Jan 5, 2016 03:21 PM
Special
Jan 21, 2010 07:55 PM
Amageus
Mar 6, 2009 05:44 PM
Crucio
Jul 28, 2008 08:42 AM
