Rogue CARBON STEERING WHEEL INSERT interest
Old Oct 31, 2009 | 10:16 PM
Rogue Fit's Avatar
I haven't posted any new pics lately so I thought I would show the latest set of steering wheel inserts in silver:
Old Oct 31, 2009 | 10:18 PM
Fitting's Avatar
Pics no workie Jim.
Old Oct 31, 2009 | 10:33 PM
Rogue Fit's Avatar
should be working now.
Old Oct 31, 2009 | 10:41 PM
Fitting's Avatar
See them now.
Just pm you.
Old Nov 12, 2009 | 12:01 AM
Fitting's Avatar
Just got done with the install today.
I'm posting pics and links for the swap below.
Disclaimer: I, FF,net, or Rogue FIt are responsible for any problems that might occur for the swap. Do it at your own risk!
Important* make sure you disconnect the battery and wait a few minutes before working on the airbag. Don't want to accidentally inflate the thing now
Here's a link I found for removing the airbag:
Driver's Airbag Replacement
The star head bolt(the red star next to it) is the one you take off for the airbag. One on each side and the airbag come right off.
The 2 blue circles are where the 2 holes where you take 2 screws off for the silver inserts. Two on each side.
Edit: added this pic of the back of the inserts.
The red dots are where the screws on the back of the steering wheel screw into the inserts.
Green dots are where the screw screw down the inserts behind the airbag.
For those that might like to just take the steering wheel off and then remove the screws behind the steering wheel for the inserts here's a link:
Steering Wheel Removal
A flap at the bottom of the steering wheel. There's a slot in it for you to put a screw driver and pry it off.
Taking the flap off allow access to the airbag harness. The connector can be pull out to make it easier to connect/disconnect the harness.
Once you take the airbag off it look like this.
You can see the yellow harness for the airbag and the black harness at the bottom is for the horn.
The silver inserts are also held on by a single screw on the inside (my screw driver is on one). Once that's off and you remove the 2 screws behind the steering wheel the inserts come right off.
If you've cruise control then you've to disconnect the green harness on the right side. The two small rectangular harness(one on each side) are for the pedal shifters just unclip them from the inserts.
Back of the airbag.
CF inserts on.
All done
Old Nov 12, 2009 | 01:22 AM
Fanatix's Avatar
Looks great. I will hopefully be ordering some soon.
Old Dec 1, 2009 | 01:08 PM
Rogue Fit's Avatar
I have one set of non-button inserts available that I would like to move this month. Just PM if interested.
Old Dec 7, 2009 | 12:36 PM
CuTeBoi's Avatar
Finally, my inserts came in handy. hahaha
Old Feb 21, 2010 | 01:17 AM
jt.wilson89's Avatar
do u have any with the bottons?
Old Feb 22, 2010 | 09:41 AM
CuTeBoi's Avatar
Yes he does, just ask for pricing (I know I left him a set with and without buttons)
USDM Sport and Base compatible.
andycampero1
Aug 26, 2015 06:48 AM
NewCar
Jun 3, 2012 05:04 PM
fitrjrob2
39
Sep 18, 2008 07:17 PM
gthumb23
Aug 19, 2007 09:47 PM
Mugen_Dom
Apr 22, 2007 08:09 PM
