Very Hot Brake Rotors
Old Nov 3, 2009 | 06:30 PM
Chad T's Avatar
Also you've got a lot a variables that can cause you to see steam at the car wash. Outside temp, water temp etc. Ever see steam when you breathe in cold weather?
Old Nov 3, 2009 | 06:46 PM
BayAreaKid's Avatar
It sounds normal if you put cold water on brake pads.
Also, do not go through ANY car wash. It is always better to wash your car at home. Those brushes in the car wash only slap your vehicle with crud leaving you with swirls, scratches etc.
Old Nov 7, 2009 | 06:48 PM
DZeckhausen's Avatar
The reason they are so hot is because they are tiny. At 262x21mm and only 12 pounds each, it doesn't take much to get these rotors very hot. After a stop, you're temporarily storing all the kinetic energy of the vehicle as thermal energy in some very small "storage" containers. (the rotors)
Now if you could install some Dodge Ram SRT-10 rotors, then you could probably touch them with your hands after a 5 minute drive! The SRT-10 rotors are 380x36mm and 40 pounds each. Of course, your acceleration would be even worse than it is and the ride and handling would be affected.
Old Nov 7, 2009 | 09:29 PM
binaryh4x's Avatar
Only when my lung is dragging.
Old Nov 9, 2009 | 11:11 AM
JFit317's Avatar
my Fit had the problem too, but...I was also mobbing the hell outta it.
Old Nov 9, 2009 | 11:15 AM
I did an experiment yesterday, since the Fit was dirty and I ran out of time to wash it, since we had guests coming over for a BBQ. So I took it to the local (good) carwash. When the spray hit the front wheels, steam came billowing out.
I hereby declare this event - Normal!
Old Feb 23, 2021 | 01:38 AM
KwazyKwaig's Avatar
Originally Posted by valk97
2010 Fit Sport - Have had it around 2 weeks and have put on about 700 miles. Took a short 5 min ride to the car wash today. During the wash, noticed the water was sizziling and steaming off the rotors. This was after just a 5 minute ride and after the car was off for almost 5 minutes. Guess the brade pads are sticking? Can only wonder how much brake pad wear I have had already not to mention the possibility of warped rotors. Heading to the dealer on Monday.
Anyone else have this problem?
Noticed a few posts where some have had the brake pads replaced after only 15k. Wonder if they were haveing the same problem and did not know it?
I realize this thread is over 11 years old but as a guy who's done all his own work on many cars for over 55 years, nearly everyone in this long thread is missing the point here.
With only a casual easy five minute drive to the car wash on level roads with a small number of stops, there's no way the brakes should should be screaming hot and causing steam clouds to emit, no matter if a hot summer day in Phoenix or a cold winter day in Minneapolis. .
Almost certainly a caliper piston is hanging up. I'm especially tuned into this with my 2007 Fit Sport manual today making front end noise at highway speeds and smelling like hot brakes when it's parked. The passenger side wheel was much warmer than driver side. I jacked up and put it on jackstands. Start car and engage first leaving it at idle. Engine stalls. Can't spin RF wheel by hand in neutral. Only one thing could cause that- sticking caliper piston. Removed pass. fr. wheel, removed caliper bolt and swiveled it up and pulled the pads. One pad worn 2mm thinner than other. Used a C-clamp to push piston back in. Required a lot of force. Exercised the caliper several times with hand braking on the pedal, repeating push back w/ C-clamp. Noticed the rubber dust boot on the piston was cracked and had a chunk missing. Car has 224,000 miles so maybe I shouldn't complain. Bought a replacement dust boot with a caliper rebuild kit also containing the square cut piston seal and a bleeder dust cap for six bucks at Advance Auto.
Will now clean up the bore and the piston and replace dust boot and all should be good to go. The cracked boot has allowed road salt water to corrode the steel of the piston and caliper bore. My point being, learn how brakes work and do your homework when a problem like this comes up to figure out what's really going on rather than guess the car wash is to blame. .
Julien Griffault
May 14, 2021 08:04 PM
wxgeek
Dec 27, 2016 07:43 AM
phenoyz
Jun 3, 2014 11:52 PM
pmartensen
Jan 11, 2013 06:08 PM
goodyonsen
May 22, 2009 06:30 PM
