HID Light Problem ;-(
Old Nov 3, 2009 | 09:34 PM
Jumarcil's Avatar
Question HID Light Problem ;-(
Hi;
I just had an HID kit installed on my Fit 2008 and the right bulb fails once in a while. At first they installed it with ballast but without a relay so when I started the car I didn't have any light at all until I started the light. But when I opened the light I had an on and off problem with the right bulb sometimes failing. They told me that by installing a relay it should fix my problem. They did install the relay but still the same on and off problem. They set it up so that when I start the car I am on the high beam and when I turn the light on, they fall back to lo beam. After they work normally but still with the rigt beam sometimes not working.
Any help greatly appreciated since I am sending back the car to the garage in 2 days and the mechanic is out of idea I guess.
thanks
Jules
Old Nov 4, 2009 | 12:15 PM
qbmurderer13's Avatar
Sell it and go back to stock, or get REAL HID system. This shows the quality of these plug and play kits.
Old Nov 4, 2009 | 01:39 PM
FITMugen's Avatar
I don't know what type of HID conversion kit you got? I bought mine from eBay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390032291858&viewitem= &sspagename=STRK%3AMEWNX%3AIT
If you follow the link you will see a diagram. You have to have a relay. Otherwise, it might void your car warranty if you had electrical issue.
The relay will get a signal from one of headlights socket. The power feeds directly from a battery. Hi and lo are controlled by Bi-Xenon Controller.
I don't have any problem with my HID yet. It has been 3 months on the FIT. However, I have HID on my 2007 Civic Si for almost 3 years now with no problem.
Please let me know if you need further assistant.
Old Nov 4, 2009 | 09:22 PM
Jumarcil's Avatar
Thanks for your help.
Jules
alanchan
23
Jun 5, 2012 12:21 PM
kroze
May 28, 2009 11:27 PM
WhEreZmYFiT
Dec 7, 2007 03:28 PM
potatoo
Jan 15, 2007 12:39 AM
07Fit00S2K
14
Jul 5, 2006 11:43 PM
