Front Stabilizer bar bushings
Old Nov 5, 2009 | 05:45 AM
Lek's Avatar
Lek
What would be the effect of front stabilizer brackets not tightned 100% or slightly worn stock rubber bushings?
This could be the answer to my problem.
Old Nov 6, 2009 | 10:32 AM
Carbuff2's Avatar
What was your problem?
On other cars I have owned, worn SB bushings would squeak because they slipped on the bar. Also might get a subtle clunk when going over bumps.
Another source of suspension noise is the end-links, #8 in your picture. It is often very difficult to pinpoint. Common problem on Generation 1 CRVs (both front and rear).
Old Nov 8, 2009 | 04:16 AM
socalsmirff's Avatar
yeah whats your prob? energy suspension has great poly replacements. its easy to install
Old Nov 8, 2009 | 06:11 AM
Lek's Avatar
Lek
Do they have them for the GE?
Old Nov 8, 2009 | 09:37 AM
Vanishing Point's Avatar
Delrin bushings are far better than Poly, but may have to be ordered for the Fit.
Old Nov 8, 2009 | 09:44 AM
Texas Coyote's Avatar
As far as I know you have to replace the link with a new one and about the only way to mess one up is to not use an allen wrench to secure the center when removing the bolt.... About $50.00 for the whole link..... The rattling is nerve racking and it makes the front end feel lose and leans as bad on the side that is not damaged as on the side that is.
kinosh
Apr 15, 2019 10:11 AM
chrisw_lfp
Aug 7, 2017 04:41 PM
fitjoe
Jan 4, 2016 11:19 PM
DrKelso
Aug 30, 2012 07:19 PM
ComposiMo
Feb 15, 2008 11:35 AM
