Honda Emblems, RED emblems, CF emblems, emblems questions
Old Aug 8, 2006 | 06:22 PM
  #121
towelie's Avatar
iHardpark
red emblem
hey all i just got my red fromt emblem for my fit today and i was wounding if their was any special way to take it off this car or is it just like any other honda and pop the old one off
thanks
Old Aug 8, 2006 | 06:53 PM
  #122
JDMish's Avatar
Just looks like the same 2 pins + 3m tape thats holding it on there.
Old Aug 8, 2006 | 07:05 PM
  #123
Keep Fit's Avatar
take some photos after you intalled
thanks
Old Aug 8, 2006 | 07:10 PM
  #124
Packy's Avatar
Frequent FitFreak Poster
Old Aug 10, 2006 | 11:21 PM
  #125
Halcyon's Avatar
Did you add more double sided tape to the DC5 emblem - mine had only 2 strips on top and bottom of the red H - still gotta get that friggin dremel
Old Aug 11, 2006 | 07:07 AM
  #126
sillypuddy's Avatar
Someone that Posts too much
the fog switch is on the headlight control stick
i added more 3M double sided tape..
-joe
Old Aug 11, 2006 | 10:58 AM
  #127
Spule 4's Avatar
While cute, nuts to the coin holder (Chicago Skyway would empty it out fast). Howzbout the EU spec headlight leveling switch instead? Fills a hole and cures a FIT problem with one move.
http://www.clean-auto.com/IMG/jpg/HondaJazzIn.jpg
Of course, you would have to install the levelling mechanisims in the NA lights, which may be difficult at best.
Old Aug 11, 2006 | 11:13 AM
  #128
sillypuddy's Avatar
the coins will not "fly out" like you think
it's in there pretty good.. i haven't had any coins fly out yet and the turns i take are very sharp
-joe
Old Aug 16, 2006 | 12:09 PM
  #129
FrogDaddy's Avatar
What if stock emblem is loose on one side?
My rear emblem is loose on one side. Do you think it's one of the pins have broken off? It's odd that's it's even happening after two months. Haven't been in any car washes.
Old Aug 16, 2006 | 02:18 PM
  #130
sillypuddy's Avatar
look up from the hatch latch to check the pins
-joe
Old Aug 16, 2006 | 07:47 PM
  #131
towelie's Avatar
iHardpark
omgthe jap interior is so much better y do they always do that i want a jap dash now lol
Old Aug 16, 2006 | 10:09 PM
  #132
FrogDaddy's Avatar
Silly, I checked the pins and they appear to be intact from that perspective but the darn thing move up and down on the left part of it. The emblem has movement so perhaps one has broken from the emblem but stuck in place?
I hate having to do a warranty trip for this because they managed to scratch my plastic on my rear arm rest repairing a interior window trim. I'm not sure they've come up to speed on disassembly yet.
Old Aug 17, 2006 | 07:20 AM
  #133
sillypuddy's Avatar
it's japanese.. not jap .. jap is a deregulatory term
-joe
Old Aug 17, 2006 | 09:10 AM
  #134
8251reefer's Avatar
deregulatory? wth is that ? Do you mean Derogatory...
Old Aug 17, 2006 | 12:54 PM
  #135
sillypuddy's Avatar
yeah that
-joe
Old Aug 17, 2006 | 04:29 PM
  #136
Soggy's Avatar
I LOVE the coin holder.
Old Aug 24, 2006 | 03:32 PM
  #137
FrogDaddy's Avatar
I just replace my stock emblem myself because one of the pins broke. The damn emblem is $22. You remove the inner panel, remove the winshield wiper, remove the wiper motor that has 3 bolts (10mm?), disconnect wiper power. Careful removing the outside panel because there is 1 bolt that needs to be removed that holds the panel on before you pull on it to release clips. Then you reassemble. Only thing I sould've done was mark the existing location of wiper. So I had to guess. You need more detail let me know. I've taken it apart a number of times. One time it was because my son pushed the cover to the tailgate release into the panel.
Old Aug 27, 2006 | 12:43 AM
  #138
towelie's Avatar
iHardpark
nop mine doesnt go over mine fits perfect i just hace a very lil gap but u cant even tell
Old Sep 18, 2006 | 06:47 AM
  #139
optionR's Avatar
DIY- Rear H emblem
1) Purchased a piece of Red Honda emblem
2) Have the following tools ready:
- 1 flat tip screw driver
- 1 plier
- 1 set of DIY tools to remove bolts and nuts
3) Remove the plastic cap on the rear wiper and unscrew the bolt on the arm of rear wiper. Removed the rear wiper completely.
4) Remove the inner board of your rear hatch, there are 2 push down plastic clips on the edge of the board. Remove these and you also need to remove the plastic holder before the entire inner board can be taken out.
5) Take out the rear wiper motor by removing the 3 screws attached to it.
6) Removed 1 screw towards the left side of the rear tailgate.
7) Pushed the plastic clips (2 blacks and 2 whites) found on the inside of the rear tailgate.
8) Use a little force to take out the exterior tailgate piece where the original H emblem is attached to it.
9) Use the piler to remove the 2 pins at the back of the original H emblem and use the flat tip screw driver to slowly remove the silver colour H emblem. Remember to use a cloth to cover the flat tip to prevent damaging the body of car.
10) After removing the emblem, clean the area with water and make sure there is no dirt.
11) Stick the red H emblem onto it and make sure its fully stick on.
12) Put back everything and done!!!
Old Sep 18, 2006 | 01:55 PM
  #140
FitSport's Avatar
UMMM...Very easy way to remove rear emblem is to take a long handle screwdriver. Open rear hatch look at panel between rear hatch handle and "H" emblem. Youll see the 2 pins that hold the emblem in place. Slip screw driver in so that the tip touches pin and smack handle of screw driver. This will cause pin to fall off. Repeat at other side pin and emblem will now come off. All without removing any panels...Very easy to do and only takes 2-3 minutes...
