04 honda pilot engine oil
Old May 4, 2005 | 11:16 AM
Gordon McGrew
Guest
Posts: n/a
Re: 04 honda pilot engine oil
On 22 Mar 2005 05:04:17 GMT, "TeGGer®" <tegger@istop.c0m> wrote:
>"mike113" <michael_yu8@hotmail.com> wrote in
>news:051097b1ce768033d4f5dd93ed267ab9@localhost.t alkaboutautos.com:
>> Hi, honda recommends to use 5w-20 oil but can i also use 5w-30 oil
>> instead. Cause they are easier to find in stores and are cheaper.
>5W-30 will do fine.
>The part-synthetic 5W-20 is intended so that Honda can more easily comply
>with government CAFE fuel economy regulations.
Everybody says that, but is there any case where a car's EPA rating
went up after Honda began recommending 5W-20? Maybe the CAFE numbers
are based on fuel economy figures calculated to three decimal places,
but I can't believe that this switch increases economy by even 1 mpg.
Sparky Spartacus
Guest
Posts: n/a
y_p_w wrote:
> jim beam wrote:
>> y_p_w wrote:
>>> That being said, Honda never redesigned their engines for 5W-20. The
>>> "mandating" of 5W-20 was likely more a business decision than an
>>> engineering choice. The same (or similar) Honda engines sold elsewhere
>>> in the world are doing fine on 5W-30 or 10W-30. In a temperate
>>> climate where I live, it might be fine. If it gets really hot, I'd
>>> worry that the oil might be excessively thin. I'd think anyone who's
>>> really freaked out, but still wants to follow the 5W-20 recommendation
>>> might consider installing an aftermarket (fin type) oil cooler.
>> you don't need to reengineer the engine - you reengineer the oil. as
>> long as it maintains its film & lubricity in the face of the kinds of
>> conditions the 4-ball test doesn't consider, who cares? as far as i'm
>> concerned, any oil, dino or syn, that uses the same technology as that
>> which can keep a 18,000 rpm, 1,000+ hp, at
>> i-don't-know-how-many-degrees F1 engine on the track for two hours is
>> quite good enough for me thanks very much. "thinness" is irrelevant.
> An F1 engine isn't going to be using Pennzoil 5W-20. Last season,
> the Ferrari team was using Shell Helix F1SL785, which isn't exactly
> available to the general public.
And is probably not a good choice for a street engine, anyway, very
different criteria. Are F1 engines torn down after every race?
Gordon McGrew
Guest
Posts: n/a
On Thu, 24 Mar 2005 23:54:32 GMT, gRmEcMgOrVeEw@mindspring.com (Gordon
McGrew) wrote:
>Precisely right. And a 0.1 mpg gain only matters if you are below the
>mandated number (I think its 27 for cars and 21 for trucks) or are
>banking credits in anticipation of dropping below in coming years.
According to the CAFE site
http://www.ita.doc.gov/td/auto/cafe.html
the penalty for missing the target is $5 per vehicle per 0.1 mpg. So
if you are below the mandated 27.5 mpg, a change across the car line
that gave you an extra 0.1 mpg would be worth $5 per car. Yeah, I
know times 6 million vehicles that's $30 million but this is big
business and you are still only talking about $5 on a $20,000 car.
And if your CAFE is already 27.5 its worth nothing.
>Are these numbers publicly available? They should be. It would be
>interesting to see how much difference a little oil viscosity makes.
Lots of interesting stats at this site but nothing by manufacturer.
(Did you know that 54.4% of all asian imports in 1982 had front wheel
drive?)
Gordon McGrew
Guest
Posts: n/a
On Wed, 23 Mar 2005 17:45:18 -0500, "Steve Bigelow"
<stevebigelowXXX@rogers.com> wrote:
>"TeGGer®" <tegger@istop.c0m> wrote in message
>news:Xns96229672627CBtegger@207.14.113.17...
>> Abeness <news@nada.x> wrote in news:kYadnQ2AOaseBtzfRVn-gw@rcn.net:
>>> I'm sure they are--even if it only goes up by 0.1 mpg, consider the fuel
>>> savings over 1,000,000 vehicles.
>> Precisely, Watson.
>> For this very same reason, automakers will spend months working to to save
>> 18˘ on one single part. Tiny things add up to big savings.
>> And in the case of fuel consumption, the government is looking at results
>> of carefully-controlled tests, and are interested only in aggregate
>> figures
>> extrapolated over an automaker's entire fleet. 0.1mpg per car is
>> significant when measured over several million vehicles.
>I thought CAFE was Corporate Average Fuel Economy...and had little if
>anything to do with total fuel used.
Elmo P. Shagnasty
Guest
Posts: n/a
In article <1111640504.2c52f0d493c8ff3ae5e79fd1f173ccd5@teran ews>,
jim beam <nospam@example.net> wrote:
> with respect, this is just supposition. i want facts. last time i was
> in a tire shop, i was listening to a guy make his choice based on which
> "looked more aggressive". was he a hydrodynamasist? how about polymer
> scientist? chemist? no. in other words, his was an utterly uninformed
> decision. when i hear stuff about "thicker is better", i think "tire dude".
Interestingly enough, the tire people know this. That's why you get
funky tread patterns. Not because they do anything, but because they
sell the tire.
Steve Bigelow
Guest
Posts: n/a
"jim beam" <nospam@example.net> wrote in message
news:1111640504.2c52f0d493c8ff3ae5e79fd1f173ccd5@t eranews...
> with respect, this is just supposition. i want facts. last time i was in
> dude".
http://www.zwire.com/site/news.cfm?n...d=482260&rfi=6
An interesting read on racing oil weights.
0W-5!
jim beam
Guest
Posts: n/a
maybe, but some definitely use mobil 1. istr valvoline being a
prominent sponsor as well. my point was that the /technology/ used in
F1 is still used in ordinary oils.
> I was under the impression that among similar oil "chemistries", a
> higher viscosity (operating temp) oil also has higher film strength.
i'm not a tribologist, but i don't believe that's true. you can use air
as a bearing/lubricant in some applications, so viscosity isn't the
final factor. as i understand it, the ability of the oil to stick to
the surface of the material is the key. the additive packages in some
modern oils are pretty darned impressive.
> Add extreme conditions (cooling system failure) and the film strength
> of a thinner oil may not be enough. Although 5W-20 may be good for
> most applications, it's still a "once size fits all" solution that
> seems to be geared towards fuel economy. I still wouldn't use it
> if I owned a Pilot and was towing a small boat. Maybe 10W-30.
> I have heard that the API standards for 5W-20 oils allow for slightly
> more zinc, and that many of the 5W-20 oils contain high levels of
> molydenum. That - and pretty much all of the 5W-20's are essentially
> semi-synthetics (as the term "synthetic" applies these days). That
> doesn't mean I trust that the average 5W-20 will protect an engine
> better than an average 5W-30.
Steve Bigelow
Guest
Posts: n/a
> Precisely, Watson.
> figures
Abeness
Guest
Posts: n/a
y_p_w
Guest
Posts: n/a
> which can keep a 18,000 rpm, 1,000+ hp, at i-don't-know-how-many-degrees
> F1 engine on the track for two hours is quite good enough for me thanks
mike113
Guest
Posts: n/a
Hi, honda recommends to use 5w-20 oil but can i also use 5w-30 oil instead.
  #32
jim beam
Guest
Posts: n/a
y_p_w wrote:
> jim beam wrote:
>>mdsimon80 wrote:
>>>Honda recomends 5w-20 weight oil for emission and fuel economy
>>>reasons. 5w-30 weight oil will probably will not cause any
>>>problems to the engine. If the engine had a turbo I would be
>>>concerned.
>>>Check out http://www.performanceoiltechnology.com/ford5w20.htm
>>to paraphrase: "using another grade of oil doesn't invalidate your
>>legal rights. so let us sell you amsoil."
> Redline fudges with many specs too, but they don't get much scorn for
> it. They seem to be more realistic in their sales and advertising.
can't say i've waded much farther than their 4-ball test. that is /so/
unrealistic for vehicle engine apps, it's not even funny. it makes no
account of changing chemical load, changing particle load, thermal
breakdown - it's just a joke.
>>what a tech-free croc. i wouldn't buy amsoil on principle. /anyone/
>>attempting to distribute a product through an ariadne's web of hype
>>like that will never get my dollar.
> I don't care for Amsoil's sales practices, and I never intend to buy
> any of their products. I don't believe they're garbage either, and
> its use seems to be working well for people without an axe to grind
> for or against them.
  #33
y_p_w
Guest
Posts: n/a
> > concerned.
  #34
Mike Iglesias
Guest
Posts: n/a
In article <051097b1ce768033d4f5dd93ed267ab9@localhost.talkab outautos.com>,
There have been lots of discussions about Pilots and oil at
http://www.hondapilot.org/.
Mike Iglesias Email: iglesias@draco.acs.uci.edu
University of California, Irvine phone: 949-824-6926
Network & Academic Computing Services FAX: 949-824-2069
  #35
y_p_w
Guest
Posts: n/a
Frank wrote:
> I don't know about you, but if the engineers who develop the
> engine say that their engine needs
> 5w-20, I would not take the chance with another grade. Also, more
> and more stores have 5w20 and
> its is only a few dollars more an oil change. So let me see.. 30k
> for the car... and I want to
> save a measly 5$ per oil change... don't think so.
Well - Honda didn't redesign many of their engines when they made the
official switch to 5W-20. Ford is back dating their recommendations
to use 5W-20. I doubt 5W-20 is some magic potion, but its use is
possibly a concious decision that fuel economy is more important than
ultimate engine longevity.
The cheapest 5W-20 oil I've seen is Coastal at an AutoZone. I wouldn't
use it, but it's a fully API certified oil with the donut, starbust,
etc.
For those who are really freaked out, Mobil 1 now comes in a 5W-20
version. I know it won't be an option for the original poster because
of the price, but it might work for those what are squeamish about
usingeven a semi-synthetic 5W-20. I'm supposing the biggest problem
would be excessive thinning out at high ambient temps, and the Mobil 1
will likely be better in that regard.
Some manufacturers that normally recommend 5W-30/10W-30 also say
that other (heavier) weights can be used with lots of towing and/or
in hot climates. Most engines are alleged to be fairly tolerant of
a wide range of oil viscosity. If I lived in (let's say) Texas, I'd
seriously consider using a 5W-30 (or even 10W-30) during the Summer.
  #36
jim beam
Guest
Posts: n/a
mdsimon80 wrote:
> Honda recomends 5w-20 weight oil for emission and fuel economy reasons.
> 5w-30 weight oil will probably will not cause any problems to the
> engine. If the engine had a turbo I would be concerned. Check out
to paraphrase: "using another grade of oil doesn't invalidate your legal
attempting to distribute a product through an ariadne's web of hype like
  #37
mdsimon80
Guest
Posts: n/a
  #38
Frank
Guest
Posts: n/a
Cheers
"mike113" <michael_yu8@hotmail.com> wrote in message
news:051097b1ce768033d4f5dd93ed267ab9@localhost.ta lkaboutautos.com...
> oil instead.
  #39
halo2 guy
Guest
Posts: n/a
you can put in vegetable oil if you want
> instead.
gOzP19
Oct 18, 2014 01:04 AM
hondafit_03
Aug 13, 2011 11:05 PM
Benggolf
Jun 26, 2009 06:57 PM
phil_qc
Sep 6, 2006 01:23 PM
mike113
May 4, 2005 04:44 PM
