View Single Post
  #1 (permalink)
Old 08-25-2006, 02:30 PM
skunk2.com skunk2.com is offline
Platinum Honda FIT Vendor
skunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to liveskunk2.com relies on Rep Points to live
Skunk2 Lowering Springs
Skunk2 Racing Lowering Springs offer superior handling performance, an aggressive stance, and an extra smooth ride. The same engineering and quality that goes into our racing springs also goes into all of our lowering springs. Each spring is CNC-wound using SAE 9254 spring steel, shot peen stress relieved, and corrosion protected using phosphate and powder coatings. The result is a spring that offers racecar handling, yet maintains smooth and comfortable ride characteristics. Skunk2 Lowering Springs lower the Honda Fit approximately 1.5” front and 1” rear. Includes two front and two rear lowering springs.
* SUPERIOR HANDLING
* AGGRESSIVE STANCE
* EXTRA SMOOTH RIDE
SPRING RATES Front: 175 lbs./in. - 3.1kg/mm
Rear: 350 lbs./in. - 6.2kg/mm
Part #: 519-05-1750
Link: http://www.skunk2.com/Merchant2/merc...de=519-05-1750
__________________
Skunk2 June Fit of the Month Winners
The Skunk2 Team
Sponsored Links
