Rotors Cracked
Old May 4, 2005 | 11:16 AM
thomas.jacobs@dva.state.wi.us
Guest
Posts: n/a
Rotors Cracked
98 prelude 115K miles. I just replaced the rear pads first time due to
rusty hand break linkage. The non vented rotor had discolored lines
that ran jagidy perpendicular to the bright wear ring. These I assume
resembled/was due to cracking. I looked on the front vented rotors and
the same thing. I don't know the rotor thickness specifications but
the rotors did not appear to have much wear. i.e. there was just a
slight lip 1/16" or less. I am interested in hearing if any body has
heard of rotors where chunks cracked off.
Are the cracks enough to make replacement of the rotors mandatory?
thanks tom
jmattis@attglobal.net
Guest
Posts: n/a
Re: Rotors Cracked
Let's put it this way:
If your rotor loses a chunk, all hell will break loose when you apply
your brakes. If it is in a hard emergency stop, you will have much
less control over the braking and possibly steering of the car. It's a
bad thing, and it can and does happen.
It sounds like they've been badly abused.
Woody
Guest
Posts: n/a
Re: Rotors Cracked
Take them to a resurfacing shop. They will tell you if they are cracks or
just surface blemishes. All answers you get here without being able to see
them will be just guesses...
<thomas.jacobs@dva.state.wi.us> wrote in message
news:1112038910.132741.137990@l41g2000cwc.googlegr oups.com...
> thanks tom
halo2 guy
Guest
Posts: n/a
Re: Rotors Cracked
I have only had cracks on my cross drilled rotors which I will never buy
again.
> thanks tom
jim beam
Guest
Posts: n/a
Re: Rotors Cracked
TeGGer® wrote:
> thomas.jacobs@dva.state.wi.us wrote in
> news:1112038910.132741.137990@l41g2000cwc.googlegr oups.com:
>>thanks tom
> You appear to be in Wisconsin. That means you are susceptible to severe
> rust, like that shown on this page:
> http://www.tegger.com/hondafaq/rustybrakes/brakes2.html
> From your description, it sounds like you've got rust buildup around the
> perimeter of the disc, and that rust is flaking off. There's a quick way of
> shaving that off.
yes, /much/ more likely this is it. actual disk metal cracking in the
braking or hub areas is very rare. and catastrophic.
> Cracks that impair the rotor's structural integrity would be visible within
> the bright area. If the swept (bright) area of the disc does not show
> cracks, then you're fine.
Tinn-Can
Feb 2, 2018 11:28 AM
TaubBaer
Jun 1, 2017 12:11 PM
Digimer
22
May 28, 2012 07:05 PM
Eugene.Atget
Oct 21, 2011 12:33 AM
p1driftfiend
14
Dec 7, 2008 10:51 AM
