2000 Civic spark plug
Old May 4, 2005 | 04:44 PM
Subhabrata Bhattacharyya
Guest
Posts: n/a
Hi group,
I replaced the spark plug of my 2000 civic with DENSO: KJ16CR-L11 spark plugs. I forgot to adjust the spark plug gap and fitted the spark plugs as I got it. The car is running smoothly and no problem both in high rev and low, or in high speed , low speed or in acceleration is noted. Apparently, they are in the right gap , i.e. 0.04". Do I need to take the spark plugs apart again to find the actual gaps? I am worried that it might develop some problem later on.
Thanks for the help,
SB
SadaYama
Guest
Posts: n/a
Re: 2000 Civic spark plug
Even though they come adjusted, for what ever is the specification, it
is a good idea to check the gap, before you screw them in -- always. In
any case, since it is bothering you, why don't you pull them apart and
check them, and put'em back.
Kevin McMurtrie
Guest
Posts: n/a
In article <d3bpqo$fv1$1@murdoch.acc.Virginia.EDU>,
"Subhabrata Bhattacharyya" <sb4st@virginia.edu> wrote:
> Hi group,
> problem later on.
> SB
It's always a good idea to check them. They're only set to the
approximate gap size.
You can fry your ignition system if the gap is much too large (over
voltage at high manifold pressure). It might fire during the
compression stroke if it's much too small (coil charging). I don't know
what happens, if anything, if it's just a little off.
John
Guest
Posts: n/a
Well, if the ignition wire has too much resistance and the spark is at
correct gap then it's the same as having normal resistance and having the
gap a little too big. So I don't think a tiny difference will make much
difference because it depends on other things in the ignition system as
well, particularly how much voltage it's sending, resistance in wires, etc.
"Kevin McMurtrie" <mcmurtri@dslextreme.com> wrote in message
news:mcmurtri-9795D0.14155110042005@corp-radius.supernews.com...
> > Hi group,
as I
low,
they
apart
> > problem later on.
> > SB
TeGGer®
Guest
Posts: n/a
"Subhabrata Bhattacharyya" <sb4st@virginia.edu> wrote in
news:d3bpqo$fv1$1@murdoch.acc.Virginia.EDU:
> Hi group,
Leave them alone. They're already pregapped to 1.1mm (.040"), which is what
the "L11" means.
I can't find what Denso's codes mean, but if they're platinum or iridium
coated, gapping the is a bad idea. The plating is thin and easily damaged
by forcing a gapping tool between the elctrodes.
Spark plugs are made to tolerances down to a thousandth of an inch. Why
does everybody figure the makers suddenly got sloppy with one single
dimension? The only way the gap is going to be off by any meaningful amount
is if the plug gets dropped with the protective cap removed.
TeGGeR®
www.tegger.com/hondafaq/
jim beam
Guest
Posts: n/a
>>Hi group,
> the "L11" means.
that's correct. never wire brush plugs either as it leaves traces of
metal on the insulator & weakens the spark.
Guest
Posts: n/a
Thanks a lot TeGGer and everybody.
That helped a lot,
SB
"TeGGer®" <tegger@tegger.c0m> wrote in message
news:Xns9635666EC15Ftegger@207.14.113.17...
> > Hi group,
what
> the "L11" means.
amount
> TeGGeR®
y_p_w
Guest
Posts: n/a
> > Hi group,
is what
> the "L11" means.
> iridium coated, gapping the is a bad idea. The plating is thin
> and easily damaged by forcing a gapping tool between the elctrodes.
While using a gapping tool on a platinum plug isn't recommended, I
find that the platinum points on a Denso plug are rather thick and
durable.
> inch. Why does everybody figure the makers suddenly got sloppy
> with one single dimension? The only way the gap is going to be
> off by any meaningful amount is if the plug gets dropped with
The manufacturer's typically recommend that the gap be checked
before installation except for platinum/iridium plugs. They
warn against it, but have regapping instructions which state
that a round gapping tool should not be used.
<http://densoiridium.com/installationguide.php>
BTW - Denso now makes a single-tip Iridium plug called "Iridium
Power". It's their standard U-groove ground electrode with an
iridium center electrode. They still have their "long-life"
iridium plugs.
ansys
Nov 11, 2023 11:41 AM
InsaneGenius
Oct 19, 2015 11:05 AM
Rollerboots666
21
Mar 2, 2015 07:46 PM
wackyflik
Oct 4, 2014 09:11 AM
TumTum2570
Jul 13, 2012 04:53 PM
