ECO-Fit DiscussionThreads discussing the pursuit of ultimate economy, hypermiling techniques & maximizing your MPG
Welcome to Fit Freak!
Welcome to Fit Freak,
A while back I read in this forum that some Fit owners claimed they could hear and/or feel the gas sloshing around in the tank under the driver's seat. Is that correct? My only experience with the Fit is a short test drive, and I didn't notice anything like that, but I wasn't really listening for it. I'm seriously considering purchasing the Fit , but I think something like that would really bug me if it was noticible. So is it common, or do you have to be hyper-sensitive to notice it?
Allen
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Don't worry about it. I am very sensitive to sound, and Fit fuel slosh, whan audible at all, is only slightly louder than my Focus was. Considering where the fuel tank is, I am amazed it is not louder. I am sure Honda considered this and took considerable pains to keep it quiet.
I hear it BARELY- but it's there. Don't hear it all while moving, only when coming to a stop. Best example, pull in the quiet garage, stop, engine off, couple of faint sloshes. No big deal.
I think it's strange, but not obtrusive, and I wouldn't NOT buy a Fit because of it...
barely audible. I actually have heard it before, but didn't realize it was the gasoline till today. It sounds like bubbles. Its real quiet. If u're listening to music or windows are down, u won't hear it.
I am just curious, but why does it sound like ice sloshing around in a ice chest when I first start the car and drive around a bit? Has anyone else notice this? Is it the coolant?
__________________
2007 "Taffeta White" Honda Fit Sport
Weapon-R SRI, Megan Street header, NHBP Headlights, JDM Smoked LED Tails
If you installed the fujita intake while the car was warm-or cold, you might have lost some coolant(you would notice!) when replacing the hoses. Those are air bubbles in your coolant lines, just add more coolant to the radiator till full and free of bubbles(when warming up the car from cold). The bubbles will escape through the radiator cap opening and allowi more fluid to fill. See Honda manual for proper amount and don't overfill - problem solved.
This is just a recommendation and I am not responsible for damages to the fit-see owners manual. Happened to me, and I overheated my engine twice before I did it the right way.
The fit is wierd because it sends coolant through the system and into the throttlebody which is higher than the radiator cap so bubbles can't get out completly while running your car. You might have to do this a couple of times till you don't hear the bubbles anymore.
Had the same issues after installing my T1R intake and having my coolant topped off. With the car on a level surface, with a cold engine, remove the radiator cap, and start the car without giving it any gas. You may cover the intake with a rag just in case some coolant spews over. You should see bubbles coming up, leaving the heater core, which is where these bubbles are causing the gurgling noise. Let the engine run until the fan kicks in, at which point the coolant level is going to drop. Hopefully by then most of the air bubbles have left the system. Cap off the radiator opening, and take it for a little drive. There should be little to no noise, and once you drive it for a while there should be no more noise. Good luck!
__________________
Alberto T., PPA
Spoon Sports, Yokohama, J's Racing, GTSpec, and T1R stuff
Modified JDM roof storage console
How much coolant did you lose/add? I am getting mine tomorrow I probably will install it at work but not bypass the coolant line until the next morning when the engine is cold. Then i will bypass it and start it up. What do ya think? Is it better to bypass the coolant line when the engine is warm or cold?
I dropped my 07 Fit Sport A/T at the Honda dealer for the SRS recall and asked them to investigate the gurgling sound I hear at idle and low speed acceleration. The service manager and technician both said they had never heard anything like it before. Sounds like it is coming from engine bay. It seemed to gurgle more after changing the auto trans from park to rev, rev to neut, etc. From that I was thinking it was transmission...but the sound is more like water gurgling from one chamber to another.
The coolant thread sounds more feasible...the Fit is still at Honda for troubleshooting.
I dropped my 07 Fit Sport A/T at the Honda dealer for the SRS recall and asked them to investigate the gurgling sound I hear at idle and low speed acceleration . The service manager and technician both said they had never heard anything like it before. Sounds like it is coming from engine bay. It seemed to gurgle more after changing the auto trans from park to rev, rev to neut, etc. From that I was thinking it was transmission...but the sound is more like water gurgling from one chamber to another.
I've seen an older thread on this site about air bubbles in the coolant making gurgling sounds...the Fit is still at Honda for troubleshooting.
Mine gurgles too!!!!!!
I have a M/T though. It happens at idle and sometimes when I come to a stop it sounds like a waterfall! I'm not sure what causes it, or if its bad or not. Maybe I should ask my dealership
