Thinking GPM is better than MPG
Old Jul 2, 2008 | 06:17 PM
RedAndy's Avatar
Originally Posted by mahout
If you take a 50 mile trip in a vehicle getting 10 mpg you use 5 gallons.
In a 20 mpg vehicle you use 2.5 gal
in a 25 mpg vehicle you use 2 gal
in a 50 mpg vehicle you use 1 gallon.
The comparison of gallons per mile is 0.1gpmi, 0.25, .04, and .02 gpmi.
Whats the difference? Both are accurate but mpg is more descriptive.
And far more meaningful to an arithmatic-challenged public.
I agree both are accurate, and really say the same thing.
But GPM makes comparisons more straightforward between vehicles, at least in my mind, because you have to have to calculate gallons used separately for each vehicle for whatever miles you want to drive before you can really compare the 2 cars. Using GPM gives you one less step to get to that point. The math is pretty easy in your example, so lets make it a little bit trickier to compare methods:
Let's say you're comparing 17mpg vs 27 mpg cars in the car lot, and you drive 1500 miles/month.
If you had both mpg and gpm on the sticker, which would you rather use to figure out how much you save each month?
Using MPG:
1) Car A gallons used = 1500 miles / 17 mpg ~= 88.235 gallons used
2) Car B gallons used = 1500 miles / 27 mpg ~= 55.5 gallons used
3) 88.235 - 55.55 ~= 32.685 gallons saved over 1500 miles
You had to divide twice and do 1 subtraction to get here.
If you wanted to do the comparison for another distance, say 10000 miles, you'd have to do all 3 steps over again, so you could again get to the gallons used for each car.
Now lets try doing the same with GPM:
17 mpg ~=.0588 gpm (pretend these were right on the car stickers)
27 mpg ~=.037 mpg
1) .0588 - .037 = .0218 gpm difference per mile between cars
2) .02gpm * 1500 miles = 32.7 gallons saved over 1500 miles
You just did one subtraction and one multiplication instead of 2 divisions and 1 subtraction. If you wanted to do the savings comparison for another distance, say 10000 miles, you only have to multiply 10000 * .0218 calculated in step 1 and you're there.
To me anyway, this makes apples to apples comparisons much more straightforward. Sorry for the long post......
Old Jul 2, 2008 | 06:35 PM
RedAndy's Avatar
Originally Posted by kancerr
why change things? if people wanna talk in gibberish(i get the point your making) let em...but most people in the us are used to mpg, why change it? the same reason we dont use the metric system. because change SUCKS. just talk in mpg and if people want to do math they can convert the numbers...seems like a waste of time to me.
Yes, change sucks, but often times not changing sucks more.
It sucks having to have 2 sets of wrenches, metric for anything made anywhere else in the world in the last 20 years. and SAE for US made stuff. When I wrench on my Harley, I need both. That really does suck.
It sucks not to be able to decipher a weather forecast when I'm traveling anywhere else in the world because we don't use Celcius (sp?), and the rest of the world does.
Ditto driving anywhere else because we use miles and the rest of the world uses kilometers.
And on and on and on. We are WAYYYYY overdue to get on the same playing field as the rest of the world, and after a short (but yes, painful) adjustment period, life will go on, and be better for it (even Harley is well on their way.....)
Old Jul 2, 2008 | 07:59 PM
kancerr's Avatar
thats true metric is better and more widely used. agreed with everything youve said redandy. we are long over due for a change
and you didnt fix anything with your sarcasm rich... ;] and its not unfamiliar if you paid attention in school, you learn the metric system...poor attempt at making somebody youve never talked to sound like an idiot. i didnt think i was being rude, but apparently i offended you. oh well. take your sarcasm and shove it.
guess i have no point, haha...and agree, my original post was right after a frustrating day of work and i wasn't thinking properly.
Old Jul 2, 2008 | 09:26 PM
RichXKU's Avatar
I'm being pro-metric system... not anti!
Old Jul 2, 2008 | 09:35 PM
kancerr's Avatar
yeah, just thought you were taking a shot at me. guess i deciphered it wrong...damn internet! ;p sorry. back on topic! ;D
Old Jul 3, 2008 | 07:19 PM
Red Iron Crown's Avatar
Gallons per mile figures should be 0.1, 0.05, 0.04 and 0.02 gpm. Guess you're part of that public.
That said, MPG is less useful for the public, as 10 -> 20 mpg seems like less of an improvement than 25 -> 50mpg, as there's fewer MPG in the difference. Comparing in gallons per hundred miles easily reveals the difference:
10mpg = 10gphm
20mpg = 5gphm
25mpg = 4gphm
50mpg = 2gphm
The problem is people have an intuitive grasp of what an MPG is, as they've been using the same system for decades. They won't intuitively grasp gphm right away, so the switch should probably be to L/100km like the rest of the world.
GTivan72
Aug 21, 2012 03:25 PM
trick
Jul 24, 2009 03:46 PM
JPGC
Feb 8, 2009 02:04 PM
NEK FIT
Aug 11, 2008 10:55 PM
Tekki
Jun 30, 2008 01:59 PM
