Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 03-24-2007, 07:03 PM
StormSilverGD3's Avatar
StormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to liveStormSilverGD3 relies on Rep Points to live
Send a message via AIM to StormSilverGD3
Thumbs up DIY OEM Fog Light install on Base Fit
After recently scooping up some OE fogs for a great price, I figured I would take some pictures of the install as I went along. Overall it took me about 2 hours. I took my time and didn't encounter any real trouble.
First things first. Remove the front bumper. This is pretty straightforward as there are 4 clips right above the grille to remove and 4 screws and about 5 clips on the underside of the bumper to remove. After that the bumper just pulls off.
The fog light kit should include the templates you'll need to use for cutting the bumper. As you'll see, there is some drilling and cutting involved here to get them to fit.
There is a plug tucked up in the driver's side fender well that you'll need to find. This plugs into the foglight harness at the bumper. It is secured with blue tape, so, it should be relatively easy to spot. Here's what it looks like.
After you get the bumper cut and get them mounted, the tough part is over. All you have to do them is plug them into their harness and reinstall the bumper.
It can be a challenge sometimes working with the harnesses at the fuse panel. I had a few extra in there to fight around because I added the keyless to my base model after purchasing it.
I'm very happy with them and the way they look. I will probably be covering them with yellow lamin-x film here in the next week or so to distinguish their light pattern and protect them from rocks and road debris.
If anyone has any questions I'd be happy to help.
__________________
The Fit is GO!
Sponsored Links
  #2 (permalink)
Old 03-24-2007, 08:06 PM
smeister's Avatar
smeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to behold
Send a message via AIM to smeister
Wow, looks really good. They will look 10x better once you get the yellow film on there. Glad you like them.
This should probably get a sticky for future base owners!
  #3 (permalink)
Old 03-24-2007, 09:13 PM
Thanks! And now that nightfall has come I checked the light output. I love the nice wide beam these things shoot. And I'm lucky enough that I don't even have to adjust them. They are aimed good.
__________________
The Fit is GO!
  #4 (permalink)
Old 03-24-2007, 10:48 PM
bestfit's Avatar
bestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to livebestfit relies on Rep Points to live
Thanks...for great write up...
Of course this should be stickyed...
__________________
MR Honda Fit Sport Automatic
2007 FIT Sport "The Honda that ZIGS"
***SOLD for $14K after 22K miles****
*NOT FAST BUT FUN TO DRIVE*
  #5 (permalink)
Old 03-25-2007, 12:44 AM
cjp_fit is on a distinguished road
Great job! Good pics and the result is top notch. Thanks for taking the time to write this up.
  #6 (permalink)
Old 05-31-2007, 09:34 AM
smeister's Avatar
I am tempted to install the new set I have...we'll see if anyone buys it or not in a few weeks.
__________________
I do HID Retrofits!
*** HID Retrofit SERVICES ***
DIY: HID Retrofit with FX35 Projectors
More HID Retrofits Competed
My Honda Fit DIY and Reviews BLOG
FOR SALE:
$1200 shipped - Clear Lens Retrofit w/ OEM FX35 HID Kit
$600 firm - Miata BBS 15x6 4x100 wheels
  #7 (permalink)
Old 05-31-2007, 07:07 PM
Spule 4's Avatar
Frequent FitFreak Poster
Spule 4 is on a distinguished road
I did not realize there was a post on this, I just did my set last Saturday.
The Honda instruction sheet is good, but I wish to point out a few things that are different between the instructions and what I found on my car (built 03/06) and a couple tips.
#16. Did not see any blue tape, but the plug is WAY up in there. Easy enough to pull down, found it by touch, not visual.
#28. The clips tend to free float on the black plastic. Make sure you line them up before installing the screw, or pinch with pliars for a tighter fit?
#36. My fuse label and the one in the kit were identical.
#39. I have keyless entry, so I had to "piggyback" the five pin connector as stated.
#40. Fuse was already there?!?!
#46. A bit of a pain to get to the 20 pin plug. Latch is toward the door/fender.
#48. Again, never did see any blue tape, the plug is WAY up in there, another feel around to get it.
#52. Be careful re-installing the side kick panel that the side moulding by the door does not get its tab that goes into the kick panel kinked. Check and see that all white plastic locking pins are in place.
#1/#54. I did not loose my radio pre-sets, but I did need to reset the clock. Had to enter radio code however. Window auto function was not impacted either.
I did install the pre cut Lamin-X yellow film. $14.95 of stone chip protection! Not as yellow as my older European cars, but still neat at nite.
__________________
Garrett
"Paradise, is exactly like, where you are right now, only much, much, better!"
-Laurie Anderson
  #8 (permalink)
Old 05-31-2007, 07:09 PM
Spule 4's Avatar
Do it, it is worth the effort.
My only complaint is we do not have a gauge indicator as on the Sport (I would assume gauge cluster the same for all cars?) so it is on the dash. So when the lights are on you get a nice bright green light reflecting right by the mirror in the side window.
__________________
Garrett
-Laurie Anderson
  #9 (permalink)
Old 06-21-2007, 11:09 PM
JaySmith's Avatar
JaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to live
Send a message via AIM to JaySmith Send a message via MSN to JaySmith Send a message via Yahoo to JaySmith
You wouldn't happen to know the part numbers for the black plastic bezels?
__________________
  #10 (permalink)
Old 06-22-2007, 01:01 AM
Spule 4's Avatar
Quote:
I have not seen them listed in the factory literature or by the parts vendors for that matter.
If you wish to change yours, a few minutes and a can of matte black paint could work.
Mr. Mx6GT89 painted his, and his headlamp units black, makes the car look a lot better than all one color up front in my opinion. Still do not have the nerve to pop open the headlights and paint them black myself....maybe soon? The last light units I painted were the plastic bits for a set of Merc Bosch W123 European units that had sunbleached many years ago.
__________________
Garrett
-Laurie Anderson
  #11 (permalink)
Old 08-10-2007, 10:37 PM
boyetssilverfit's Avatar
boyetssilverfit is on a distinguished road
Help On Fog Lights Installation
Guys i need your help,i tried to install my foglights today my problem is instruction number 48.
48.Locate the 2 pin connector blue taped to the vehicle harness.Remove the blue tape to free the connector.Plug the switch harness 2-pin connector into the 2 pin connector you just freed.
i been looking for the BLUE taped for at least half an hour already & i cant find it,i hope somebody here in this forum that can help me.
  #12 (permalink)
Old 08-10-2007, 11:24 PM
spule,stormgd3, where are you guys's ,i need help
  #13 (permalink)
Old 08-11-2007, 12:30 AM
smeister's Avatar
It is pretty much next to the fender. If you peel back the plastic lining you have to reach all the way up there to get to it. If you have a SUPER hard time then just take out the headlight and then you can get to it easily.
__________________
I do HID Retrofits!
FOR SALE:
  #14 (permalink)
Old 08-11-2007, 01:19 AM
i'm already in instruction no.48 which is the connections inside the fuse panel,thats way to far for the wire to reach it,
  #15 (permalink)
Old 08-11-2007, 01:59 AM
It wasn't easy to find or get to, but it is definitely tucked up in the driver's side fenderwell.
You can see by my 5th pic down that it is hidden pretty well.
__________________
The Fit is GO!
  #16 (permalink)
Old 08-11-2007, 02:35 AM
To:stormsilvergd3,
you & smeister are talking about instruction no 16.which is the 1 - pin connector,i'm already in instruction no.48 which is a 2 pin
connector,this 2-pin connector is wrapped alledgedly in BLUE TAPE.
  #17 (permalink)
Old 08-11-2007, 09:54 AM
Spule 4's Avatar
Exclamation Step 48, the painful plug behind the dashboard
Quote:
Originally Posted by boyetssilverfit View Post
To:stormsilvergd3,
Yes, this plug was the least fun and most time consuming part of the entire project. I was working in the dark (both physically and due to location) by this point. I NEVER saw any blue tape either.
The method I used was "feel around until I found a loose plug and put it in". It (I THINK) was on the left side or above the fuse box. This tactic is left over from Merc S class climate control repair days.
The only real bit of asistance I can give is the plug is grey in color. I just went out and looked at my fuse box area. It does not have much wire going to it either, I think one very thin wire is it.
Sorry, I wish I could give you more, but it REALLY is a pain to find.
Best wishes and good luck!
__________________
Garrett
-Laurie Anderson
  #18 (permalink)
Old 08-12-2007, 12:04 AM
To Spule or Stormsilvergd3,
heres a picture that i took,its wrapped in a BLACK TAPE but its wires are connected to the front panel,i'm not sure if this is the one,the color of the switch is GRAY and it fits perfectly on the switch harness.fig.1 shows the 2 pin gray switch,fig.2 shows when its connected to harness.
but when i tried to turn on my switch the foglights did'nt do nothing.,
  #19 (permalink)
Old 08-12-2007, 12:13 AM
smeister's Avatar
Oh okay, I thought you had already found that one. Again, its behind one of those fat wires. It is pretty hard to find, but once you feel around you will eventually find one lonely guy taped there. It is definitely IN there though. AGAIN, the picture is pretty accurate where the item is located. GL!
__________________
I do HID Retrofits!
FOR SALE:
  #20 (permalink)
Old 08-12-2007, 12:47 AM
smeister,
its very very hard,i thought its the one coz it fits but its not,i will try again tomorrow,too dark already,of all the mods that i did this one is definitely the hardest,my back hurts already,hopefully i will find it,
Reply
Tags
aftermarket, diy, easiest, fit, fog, honda, hot, install, installing, light, lights, map, model, oem, plug, shift
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
JDM style 3rd brake light DIY! koolkevin1107 Fit Interior & Exterior Illumination 61 01-19-2009 12:31 PM
Honda JDM Blue Foot Lights - Pre-Install. HollywoodFIT Fit Interior & Exterior Illumination 21 12-14-2008 04:44 AM
Map Light Install? Raaaaaaaaaay. Fit Interior & Exterior Illumination 2 12-27-2006 07:03 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
