Bulb Size Chart
Old 05-25-2006, 08:38 AM
sillypuddy's Avatar
Someone that Posts too much
thanks
-joe
Old 05-25-2006, 09:55 AM
wyy183's Avatar
Originally Posted by gguest
<snip>The turn signals required I add a resister to each pigtail to flash properly.
What resistor did you use? Where did you get your LED replacments?
Thanks.
Old 05-25-2006, 10:12 AM
gguest's Avatar
I used a 10 watt 10 ohm for each turn signal bulb. i got those at Radio Shack. I got the bulbs at superbrightleds.com. They also have the resistors. I'll try to get some pics together.
Old 05-25-2006, 10:40 AM
wyy183's Avatar
I found this at: http://www.sylvania.com/ConsumerProd...RG-Results.htm
2007 HONDA Fit
High & low beam headlamp
9003
9003ST Silverstar High Performance Lighting: The Whitest and Brightest Halogen
9003XV XtraVision Halogen Upgrade: Up to 30% Brighter
9003CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
High mount stop light
7440
Fog/Driving light
H11-55W
License plate
168
Back up light
7440
Rear sidemarker
168
Dome light
DE3175
Trunk/Cargo area
168
Old 05-25-2006, 11:21 AM
dougiepants's Avatar
Avid FitFreak Poster
Damn you are getting it done
Old 05-25-2006, 01:32 PM
gguest's Avatar
I put an H9 in my fog lights. It is much brighter. You just need to do some lite modification with a dremel tool.
Old 05-25-2006, 01:42 PM
aziatiklover's Avatar
Master FitFreaker
2007 HONDA Fit
9003
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
7440
Fog/Driving light
H11-55W
License plate
168
Back up light
7440
Rear sidemarker
168
Dome light
DE3175
Trunk/Cargo area
168
wow even ore thanks man
Old 05-25-2006, 02:56 PM
fad3r's Avatar
Thanks man! I ordered a 9LED dome lightbulb to replace the dinky stock one. Hopefully, I can see the cabin area more.
Old 05-25-2006, 08:38 PM
sillypuddy's Avatar
higher wattage H9 bulbs will probably cause you to burn out the harness
-joe
Old 05-25-2006, 08:48 PM
gguest's Avatar
I replaced a 1250 lumen 55 watt H11 with a 2000 lumen 65 watt H9. I think I'm OK.
Old 11-26-2006, 12:44 PM
Fit of RAGE's Avatar
  #32
Old 01-26-2007, 05:18 PM
Deivioncrx's Avatar
If anybody wants just a Clear Bulb for the Front Corner Marker its 2825, same wattage as the 2827, but in a clear bulb, not amber
  #33
Old 04-17-2007, 09:54 PM
K20A's Avatar
So the front lights uses 9003 or H4 or are they the same thing?
  #34
Old 04-18-2007, 12:04 AM
BigBadMadMan's Avatar
Sooooooooooo...an 80-watt H11 bulb yellow bulb to replace my fogs is going to cause problems?
  #35
Old 12-09-2007, 08:55 PM
ghibli99's Avatar
Thanks for the guide! I have a pair of PIAA mirror orange 7440s from my WRX that will be going into my Fit. Love it when it works out that way.
-Mike
  #36
Old 12-13-2007, 05:41 PM
LuxuryFit's Avatar
HELP!!!
Is that the same bulb that sits at the very top of the front headlight?
Thanks
  #37
Old 12-16-2007, 04:44 PM
JaySmith's Avatar
Is anyone using the 168 LED Bulbs from PIAA by chance?
  #38
Old 12-18-2007, 08:12 PM
randomracer's Avatar
any one know that bulb size in the gauges if there is any... want to swap out for brighter ones
  #39
Old 12-23-2007, 12:28 AM
holloway2006's Avatar
I was wondering if the (running lights?) The lights on top of the headlight were a 194 type. I was wanting to replace it with a blue bulb, possibly LED and was trying to find a working bulb. Also, if I replaced it with an LED would it still work the same? Would I need an adapter of some sort?
Edit: It is the 2827/2825 bulb I need, but is there one in blue? Would still prefer an LED...
  #40
Old 01-01-2008, 02:06 PM
ebcspace's Avatar
Parking Light Bulb Replacement
"2827" bulb is a little more challenging to search and find...
WY5W bulb type comes up for that "parking light/marker light" location in the Fit headlight if you go to the honda e-store at
Honda eStore
and follow the parts links to the headlight assembly.
the WY5Y bulb, also known as W5W, is listed quite a bit on ebay....
blue w5w
or blue w5w LED
keep in mind that since that bulb is in a very visible location...
for appearance, you may want to choose a bulb with an unlit appearance easy on the eyes.
(if you put an ugly looking bulb there, you will see the ugly looking bulb)
the load resistors for LED's are needed for flashing bulbs, such as turn signal bulbs. otherwise, your turn signals will spaz into hyperflashing speed.
depending on where you are, blue bulbs there may be illegal.
e.b.
Quick Reply: Bulb Size Chart
