Bbs rs 7,5x16
Old Feb 11, 2009 | 11:09 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
and here is a picture before he painted them and got the bigger lips:
Old Feb 11, 2009 | 11:19 AM
xmathx's Avatar
nice car :P Sorry if don't understand everything you write im french. :P
Old Feb 11, 2009 | 11:22 AM
MNfit's Avatar
Originally Posted by Kyle is raaddd
towelie = eriel.
here is a teaser of his BBS's
that is bad ass, I want more pics!!!
Old Feb 11, 2009 | 11:26 AM
oh okay, that's fine.
i understand.
yeah his fitment is so nice.
that's the only pic he's "released"
he's getting quality ones soon
Old Feb 11, 2009 | 11:40 AM
towelie's Avatar
iHardpark
dam u guys beat me to the punch lol thanks kyle
Old Feb 11, 2009 | 11:43 AM
haha you know how i roll
and we want more pics!!
make us happy!!!!!!!!!!!!
Old Feb 11, 2009 | 11:44 AM
xmathx's Avatar
realy nice fit towelie .
Old Feb 11, 2009 | 12:03 PM
towelie's Avatar
iHardpark
haha thanks guys but no pics yet im waiting for my fronts to come in they sould be here in like 4 days then after i slap them on then ill go take pics
Old Feb 11, 2009 | 12:04 PM
ahh okay good, i'm excited!
Old Feb 11, 2009 | 03:30 PM
mikejet's Avatar
Wow I was just going to ask this question. Now time to save up for some legit rims!
Old Feb 12, 2009 | 09:34 AM
xmathx's Avatar
Do you think is better a rim in 16x7 or 16x7.5 for the 2009 fit ?
Old Feb 12, 2009 | 01:19 PM
  #32
mahout's Avatar
The 16x7 is more common and is just as good as the 7.5; just make sure you have the correct offset: not less than 42 mm on 7x16.
Old Feb 12, 2009 | 03:58 PM
  #33
mikejet's Avatar
What offset for 15X7? I found some refurbished RS rims in the $1k price range. Anyone know if that is a decent price?
Old Feb 12, 2009 | 07:34 PM
  #34
mahout's Avatar
The 42 minimum offset is for any 7" wide wheel and could apply to 7.5" in select cases.
$1k = $1000 way too pricey. Anything under $100 per wheel is fair game bot DisCpountTire has wheels for $85 each.
DO NOT FORGET TO CHECK CLEARANCE AROUND CALIPERS, HUB BORE< AND BOLT CIRCLE.
Old Feb 13, 2009 | 11:18 AM
  #35
xmathx's Avatar
Any link that I can understand the offset things loll when you say 42mm is a smaller or a bigger offset than 52mm ? what's the offset of the original Wheels on the Fit 2009 Sport ?
Old Feb 13, 2009 | 11:19 AM
  #36
i'm pretty sure the OEM offset is 55, and the lower you go, the better it looks, but you run into small problems like rubbing, but they can all be fixed by rolling your fenders, doing little tricks, ect
Old Feb 13, 2009 | 11:29 AM
  #37
xmathx's Avatar
ok thx , but I don't want to do a lot of modding. The only modding I will do is problably lower the car like you said to a better look and put a Double Din Kenwood DNX8120. Ok so anything in 55mm to 42mm I will be fine for no rubbing .
Old Feb 13, 2009 | 11:30 AM
  #38
yeah you should be fine, and it all depends on what your being dropped on
if you roll your fenders (and sometimes needs no fender mods) you can maybe pull off 35 just fine
Old Feb 13, 2009 | 12:13 PM
  #39
mikejet's Avatar
Would these fit fine on a GE?
15x7+25 pcd 100
That's the description of the rims I want. I know they will look small and I know there will be space since I'm not lowering.
Old Feb 13, 2009 | 01:14 PM
  #40
mahout's Avatar
The minimum is the smallest number accepted for Fit wheels to avoid truoble on stock height. When lowered the offset number has to increase.
For 08 stock offset was 55 mm; for 09 53 mm.
Offset is the distance the hub is into the wheel. When the wheel center is lined up with the hub there is zero offset.
When I say the minimum offset is 42 it means the hub must be 42 mm outward from the hub. If the offset is less than 42 mm the wheel is pushed outward from the hub, meaning its likely to rub something. The safe range is between 53 and 42 mm for stock height and 48 to 53 lowered no more than 1.5" for wheels to 7" wide.
