next lowest drop from skunk2 springs?
Old Oct 6, 2008 | 04:20 PM
pwnstar's Avatar
ok so my skunk2's arnt low enough in the back (anyone know if i can take out the rubber under the spring to drop it about a 1" more or will that be bad?) or whats the next lowest drop on a set of springs progress?
EDIT: Or should i just forget about new rims and get some Pro C's>??
Old Oct 6, 2008 | 10:55 PM
radareclipse's Avatar
Stop messing around and do the Pro's. If you remove the rubber, you will have some metal on metal noise. Other than that, I'm not sure.
Old Oct 7, 2008 | 12:11 AM
kylerwho's Avatar
spoon fed
the rubber bumper helps keep the spring seated. if you removed it when you go through a dip the spring could pop out. save your money and go for pro's or get the progressive spring set. they are 1.3" drop all the way around. i think skunks are 1.5 in front and 1 in the rear. kinda looks like your shaking your ass at the car behind you.
Old Oct 7, 2008 | 10:31 AM
pwnstar's Avatar
or i might just buy the progress and just put the rear springs in and leave the skunk2's in the front i like the stance of the front.
EDIT: can somone link me the thread or a web site that lists all the springs, rates and drops please.
Old Oct 7, 2008 | 11:20 AM
cojaro's Avatar
If you're looking for a maximum drop on stock shocks, good luck. You might as well go ahead and buy the coilovers before the stock shocks blow. It'll be cheaper and safer that way.
Old Oct 7, 2008 | 01:59 PM
Nerv2g's Avatar
I'm with you I love the way my skunk2's look on the front but the back is crappy. I was debated on cut the springs but that would be crazy. I figure if i'm gonna go through the hassle of taking the springs/shocks of the only thing that will be going back in there place is full coilovers
Old Oct 7, 2008 | 05:58 PM
or just remove the rear springs and get a super low ride for free.
get the coilovers if you are THAT picky about the height. or throw some sandbags
in the back. lol
jdmjunkie561
Apr 14, 2009 07:56 AM
im the fit
Mar 19, 2009 12:37 AM
fung88
Sep 12, 2008 08:30 AM
YeeFit
17
Apr 19, 2008 06:02 PM
pastadog
22
Mar 13, 2008 12:45 PM
