Negative Camber?????????
Old Mar 6, 2009 | 02:12 PM
Illmatic07's Avatar
So I got my coilovers installed and I'm pretty low in the front. When I go to get my alignment I'm thinking of having them set a little negative camber in the fronts to keep rubbing down. What is a good setting(degree) to ask for? I'm kinda a noob on this subject. I know the tires will where but I don't want it to be really fast. Any advice would be great.
Old Mar 6, 2009 | 02:15 PM
redrumm's Avatar
wont wear if done right. buy some camber bolts....SPC on ebay are like 20 bucks
Old Mar 6, 2009 | 02:22 PM
Illmatic07's Avatar
What is the benifit of camber bolts? My coilovers are camber adjustable in the fronts.
Old Mar 6, 2009 | 02:44 PM
sam21's Avatar
check out my thread in the pictures section. I used Ingalls bolts and the tech and I were able to get -2.6 degrees out of them. It really depends on how low you are/want to go.
Old Mar 6, 2009 | 03:45 PM
if mine were adjustable i'd probably do -1.5 to -2 on the fronts
and keep the toe at zero.
if you don't set the toe aggressively your tires will wear
pretty flat (given that you dont take super fast turns and
wear the outside shoulders...then you'll want more neg camber).
Old Mar 6, 2009 | 04:25 PM
speedoholic's Avatar
Suspension Tuning - Carolinanissans.com
^ There is the best suspension write up I've ever seen. Enjoy.
Old Mar 6, 2009 | 04:43 PM
rvall004's Avatar
I got -3.0 which is the most u can out of the camber bolts
Old Mar 6, 2009 | 05:01 PM
redrumm's Avatar
haha good god what for?
1.5 to 2 would get rid of the rubbing? i didnt know they made coilovers with camber adjustments for our cars.
depending on how much camber you can get from your coilovers try that if it doesnt work then go with the bolts to fix that rubbing
Old Mar 6, 2009 | 05:11 PM
cojaro's Avatar
Since tire wear is your concern, I'd say between -0.5* and -1.0*
-1.5* or more will start to compromise tire life.
Old Mar 6, 2009 | 05:49 PM
redrumm's Avatar
not that bad.
Old Mar 6, 2009 | 05:54 PM
rvall004's Avatar
I got the -3 cause im runnig 15x8 0 offset all around
Old Mar 6, 2009 | 05:56 PM
solbrothers's Avatar
tires do not wear more because of camber
Old Mar 6, 2009 | 05:57 PM
toe kills tires, not camber
Old Mar 6, 2009 | 06:09 PM
redrumm's Avatar
pray to gawd
Old Mar 6, 2009 | 06:11 PM
cojaro's Avatar
To an extent, yes. Toe does affect tire wear more than camber, but that doesn't mean camber doesn't effect it at all. He said he's going to run 0 toe anyway, so toe won't be an issue (at least up front).
Old Mar 6, 2009 | 06:34 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
If youre low, go as negative as you can.
It wont wear.
Since my coilovers were installed I STILL havent got an alignment. No feathering or nothing yet.
And Im as negative as the Skunks will let me. Keep in mined Im running OEM strut bolts still. My camber looks similar to when I had Ingalls on stock struts.
-2 to -2.5 degrees? I never got a print out when I got my alingment a while back.
Old Mar 6, 2009 | 08:19 PM
KaufenCialisOnlinea's Avatar
From: BILLIG CIALIS ONLINE KAUF CIALIS EUR 1.25 per pille KAUFEN CIALIS Deutschland
BILLIG CIALIS ONLINE CIALIS KAUFEN EUR 1.25 per pille KAUFEN CIALIS Oesterreich
KAUF BILLIG CIALIS Generic Cialis 20mg x 60pills for $149.99 !
Deutsch lernen im Rhein-Sieg-Kreis - Forum - Profil ansehen: CialisKaufenBillig
CIALIS KAUFEN REZEPTFREI BESTELLEN CIALIS CIALIS online kaufen
Tadalafil, angeboten unter dem Namen Cialis, ist eine neue Gruppe von Medikationen, welche adaquate sexuelle Stimulation erlaubt, die Blutgefa?e des Penis entspannt und der Erektion hilft. Die empfohlene Dosis von Tadalafil betragt 20mg.
Cialis ist das einzige Medikament, welches nicht nur schnell wirkt (wirkt in 30 Minuten) sondern auch bis zu 36 Stunden effektiv bleibt, das Ihnen ermoglicht den richtigen Moment fur Sie und ihren Partner zu wahlen. Sie konnen Cialis am Morgen einnehmen und Sie sind bereit fur den richtigen Moment wahrend des Tages, Abends oder auch wahrend des nachsten Tages. Millionen Manner wurden von der effektiven Wirkung in Milde und von der gema?igten oder harten erektile Dysfunktion von Cialis uberzeugt.
KAUFEN CIALIS OHNE REZEPT - CIALIS OHNE REZEPT KAUFEN
CIALIS KAUFEN BILLIG CIALIS KAUFEN CIALIS Apotheke
KAUF REZEPTFREI CIALIS - KAUFEN Preiswertester CIALIS
CIALIS KAUFEN CIALIS BILLIG KAUFEN ONLINE FREE CIALIS
CIALIS KAUFEN OHNE REZEPT - KAUFEN REZEPTFREI CIALIS
CIALIS KAUFEN KAUF CIALIS CIALIS online kaufen
REZEPTFREI CIALIS KAUF - CIALIS KAUF ONLINE
CIALIS KAUFEN Kaufen CIALIS in Deutschland CIALIS online bestellen
CIALIS KAUF - CIALIS BESTELLEN OHNE REZEPT
CIALIS KAUFEN CIALIS ONLINE KAUFEN CIALIS® kaufen
BESTELEN BILLIG CIALIS ONLINE - CIALIS BILLIG OHNE REZEPT KAUFEN OHNE REZEPT
Old Mar 6, 2009 | 09:07 PM
Spam^^^^^^
Old Mar 6, 2009 | 09:09 PM
Illmatic07's Avatar
Thanks for all the help guys. Probably gonna go with -1.5 to -2.0. Sounds like that will be the best. P.S. Will the mods get rid off this wiener enlargement add above this post of what? +rep for all who I could give it too
Old Mar 6, 2009 | 09:24 PM
redrumm's Avatar
rep right back brah
