2015 fit door leak
2015 fit door leak
I've had my 2015 fit for a month now. Less than 700 miles and my rear driver side door is leaking. Appears to be a seal issue but did also notice the driver side doors are flush with the roof whereas the passenger side doors are inset a little. Is my car uneven or are my doors offset? Have an apt Monday at dealer.
What did you find out? I bought my Fit on Sat. and this morning when I opened to door (it had rained a little last night) I saw water droplets along the door frame. The dealer called today to check up on me, so I mentioned it and he thought it was just water dripping in from opening the door.
When I picked the car up on Sat (I didn't notice it until I got home) there were dirty water droplets in all of the door frames from the detailing. It kind of made me wonder. I might have to spray it with water to double check. I need to bring the car to the dealer anyway because it seems it might have a clearcoat issue around the Fit decal.
Door leak
My Fit is currently at the dealer. They say they ran it through the car wash and sprayed it several times and nothing. On two separate occasions it has leaked when raining heavy. The door that leaks seems to stick out further at the top than the door on the other side. I honestly think the shape of that door itself is the issue. They have an expert who deals with leaks only coming Friday to check it out. I'll keep you posted.
Spacecoast
83
08-03-2017 01:47 PM
p1driftfiend
09-20-2011 12:01 AM
